05-15-2018, 01:32 PM | #1 |
SBC vs LS Engine Location
So I plan to do a LS/NV3500 swap in the future and currently have a 350/TH350 setup. The issue I have is the motor is good but the trans is not so I would like to convert to the NV3500 now and LS later. I however don't want to make a crossmember/cut the driveshaft etc. twice. Would the SBC engine and LS rest in the same location so if I install the NV3500 now, I wouldn't need to move it later (or move it very minimally so I can just slot the crossmember and take up the play in the driveshaft) when installing the LS? Thanks.
05-15-2018, 07:11 PM | #2 |
Post Whore
Re: SBC vs LS Engine Location
I used the adapter plates that positiin the rear of the LS where the sb was...
05-16-2018, 04:41 PM | #3 |
Perfect, thanks. What mounts are you using/what are some options to have the LS sit in the same place as the SBC?
05-18-2018, 08:11 PM | #4 |
Post Whore
just ebay adapter plates is what I used.....for stock location...
