Old 05-15-2018, 06:49 PM   #1
MacQuigley
Fender Flaring
Guy's I need to flare out my fenders or space them out a bit as the new wheels and tyres I bought are just a little too tight.
Any suggestions on ways to do this?
MacQuigley is offline   Reply With Quote
Old 05-15-2018, 07:00 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Fender Flaring
Fleetside, or Stepside?
66 C20 Service Truck:
Old 05-15-2018, 09:19 PM   #3
hotrodder
Re: Fender Flaring
If you know a good bodyman that is good with a hammer and dolly the inner lip of the fender or bedside can be rolled in and you can gain some clearance that way. I did that on my 66 and got about 1/4 inch. Taking it slow will make it possible to do it without doing any body work or painting.
hotrodder is offline   Reply With Quote
Old 05-15-2018, 11:51 PM   #4
Captainfab
60-66 Nut
Re: Fender Flaring
Since you don't have your bed wood installed yet, you might consider widening the whole bed and inch or two. There was a former member here that did that to his stepside bed. I'll have to see if I can find his build thread.
Edit: I think his build thread here must be gone as I can not find it. This is the best I could do with a link to a thread elsewhere.
http://www.67-72chevytrucks.com/vboa...d.php?t=452520
Old 05-16-2018, 12:48 AM   #5
mfm3
Active Member
Re: Fender Flaring
I used one of these and gained 1/2" of additional clearance on each side. I'm guessing you can do the same on a fleetside.
https://www.eastwood.com/ew-fender-r...SABEgL5ZfD_BwE
You'll need one of these if you are running 6-lugs
https://www.eastwood.com/fender-roller-adapter.html
mfm3 is offline   Reply With Quote
Old 05-16-2018, 01:00 PM   #6
MacQuigley
Re: Fender Flaring
Stepside
Old 05-16-2018, 01:02 PM   #7
MacQuigley
Re: Fender Flaring
Would be a bit far for him to travel unfortunately. I'm in Scotland!
Old 05-16-2018, 01:03 PM   #8
MacQuigley
Re: Fender Flaring
[URL="https://www.eastwood.com/ew-fender-roller-w-instruction.html?SRCCODE=PLA00010&gclid=EAIaIQobChMIz9K276-J2wIVAQppCh3TTwosEAQYASABEgL5ZfD_BwE"]
There are some Eastwood retailers over hear. Wonder if they could get that for me.
Old 05-16-2018, 01:05 PM   #9
MacQuigley
Re: Fender Flaring
Thanks John.
Old 05-16-2018, 01:07 PM   #10
MacQuigley
Re: Fender Flaring
By way of a bit of an update, last night I bounced the bed as much as I could to see if the fenders came in contact with the tyres.
Now, Ok I know I don't have the bed wood in yet but equally Ive no shocks fitted. With the bed bouncing a good bit there was no contact. So I feel a little rolling of the inner lip of each fender should do the trick. It should be enough.
Going to have another look tonight.
Old 05-16-2018, 04:55 PM   #11
MacQuigley
Re: Fender Flaring
Had a good look tonight and I put the edge strip of wood in so it raised the bed up 1/2" and you know what it clears, only just but it does clear.
I guess if it was to really bottom out and the wheel come right up into the fender Id have a problem but I not offroading it. Its purely a fun/show truck. It will most likely have next to nothing in the bed other than a tent and supplies. I think it will be OK.
I will bring the inner lip in a little though just to be sure and give a little clearance (still going to look at that Eastwood tool though).
Old 05-16-2018, 05:01 PM   #12
MacQuigley
Re: Fender Flaring
Eastwood fender flaring tool, readily available in the UK! Yipee - for once!
Old 05-16-2018, 05:38 PM   #13
LostMy65
LostMy65's Avatar
Re: Fender Flaring
It may not be an issue, but if you have a short panhard bar, the rearend will have some side to side movement as you go over bumps.
Old 06-11-2018, 12:50 PM   #14
racecougar
racecougar's Avatar
Re: Fender Flaring
I formed 1/2" roundstock to the shape of the opening, rolled the sheetmetal around it, and welded it up.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
