11-11-2003, 08:33 PM | #1 |
91 Burban front end....
When swapping out an 81-87 front end for a 91 Suburban front end, what has to be changed? Can I still use my hood and front fenders? I was told that all I have to change is the rad support and grille. Is this true?
Kent Ballan ANY MAN CAN BUILD A TRUCK, BUT IT TAKES A REAL MAN TO CUT ONE UP! |
11-11-2003, 08:35 PM | #2 |
www.73-87chevytrucks.com
Yep, that is all....
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
11-12-2003, 02:04 AM | #3 |
UH...HUH
Also the lights and the wiring harness.
Chuck '85 Chevy Silverado 4X4 '91 Chevy 4X4 Suburban http://www.cardomain.com/memberpage/545941 |
11-12-2003, 02:08 AM | #4 |
OOOH, I forgot about the wiring harness! Thanks guys!
11-12-2003, 02:19 AM | #5 |
i'm new to these years...what is different between say an '85 blazer front end and the '91 burban?
-'02 Chevy Avalanche, 5.3L, 4x4... needing a small lift and bigger tires -'72 Chevy C-10(350, bored 60 over)dual flowmasters, 3 on the tree -'85 K5 Blazer,305 NO MORE...350 is in,2" lift,33" Mickey Thompson Baja Claw Radials -dads '70 burb (red, 5-7 drop, 350...) www.geocities.com/userc10/truckhome.html AIM: Auntjoedadda |
11-12-2003, 02:20 PM | #6 |
81-87 has stacked 4 headights, 88-91 has horizontal 4 headlights.
11-12-2003, 03:19 PM | #7 |
Hey Chris, you weren't down my way this past weekend were you? There was somone at the race track Sunday that could have passed for your twin.
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
11-12-2003, 06:10 PM | #8 |
Nope, sure wasn't. They would have to be my triplet though. I already have a twin
11-12-2003, 06:27 PM | #9 |
Are the fan shrouds the same ? I put a 91 clip on my 87 and the fan shround hit's the fan.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
11-13-2003, 03:37 AM | #10 |
Will the 81-87 fan shroud not work? I would think that it should fit on there.
11-13-2003, 04:14 AM | #11 |
shroud should work, you gotta get all your nifty adjusters and springs for the lights too, then you get to re-wire your stock harness with all the new ends..I just finished it and really its a cake walk.
Daily Driver: 1992 Blazer dropped on rallys Project: 87 GMC shortwide, About to get a little boost |
11-13-2003, 12:30 PM | #12 |
all the color coding on the wire are the same. just cant wire the green HIGH BEAM wire. you have to do that with a relay, but thats if you want all four lights on on bright. other wise just leave that wire unhooked. if you splice that wire in on the other head light , it will come on when you click your highbeams but wont go off. that is why you need the relay, so it will be switched.
2004 Silverado Crewcab 1972 Chevy Monte Carlo 2017 Chevy Tahoe |
