need advise on my column shifter / 4L80e
I have a 68 C10 and my plans are to drop a LS3 with a 4L80e into it. I would really like to keep a column shifter. Do you know if there is linkage out there that will allow me to do that ?
Re: need advise on my column shifter / 4L80e
Lokar has a linkage setup and a cable setup that will work for you.
Thanks , I just looked it upon Lokar.com and that should do it
you will need the 26" piece. i do not recall the part number. the 21" (i think) will not work.
1970 Custom Original 400/400 Now ZZ454/4L80E/Edelbrock Pro-Flo 4/3:73 Eaton Posi PS PB and cold factory air Early Classic 4.5/6 Front 20X8.5 Riddler 4.75 inch bs Pirelli 255/40/20 Rear 20X10 Riddler 5.5 inch bs Toyo 295/40/40 Rear end is original wide 6 lug converted to 5 lug |
