Old 05-21-2018, 10:13 AM   #1
CATCHALLBLUE
CATCHALLBLUE's Avatar
Carburetor 292 mystery
Hey y'all.
Been a while since I've been here but started to restore my 69 c30 again.
Pulled the Carb off with a # 7029021. Doing a little research found this Carb was originally meant for a 250 inline. Im confused as heck now. The 292 Carbs were supposed to be 7029012 and 7029022.
Also from reading in the shop manual the 292 Carbs have a thermostatic coil running into the carb?
None to be found on this particular carb. What the deal with the thermostatic coil. Am I screwed without it?
I want to buy a new carb and make sure I get the right part. What do you guys think?
CATCHALLBLUE is offline   Reply With Quote
Old 05-21-2018, 12:03 PM   #2
CATCHALLBLUE
Re: Carburetor 292 mystery
ok been doing more research and it seems my truck, 69 C30 292, had an auto choke. I dont see anywhere on the dash a choke might go.
So im going to order this carb from rock auto https://www.rockauto.com/en/moreinfo...026&cc=1033445
My question is this...Do i need this kit http://www.carburetor-parts.com/Mono...it_p_4128.html ???
Or should the thermostatic coil come with the carb? Where exactly does the electric kit go?
Old 05-21-2018, 12:40 PM   #3
geezer#99
geezer#99's Avatar
Automatic choke would have a coil attached to the manifold like the one in this link.
https://www.google.com/search?biw=13...WB7M8SRY1RYlM:
Is yours there?
Old 05-21-2018, 01:42 PM   #4
BCOWANWHEELS
Those manifold choke coils are not available anymore. Go manuel choke.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 05-21-2018, 01:43 PM   #5
CATCHALLBLUE
No, My Carb is definitely from a 250. The previous owners/users did lots of jimmy work on this truck so im still trying to figure this all out.
Called a few people and found out its not necessary to have the coil for the carb to run properly, its basically a cold start guarantee. I could put it on in the future if i feel its needed.
I ordered a new Rochester MV Carb with auto choke from California. Hard to find carbs for these trucks nowadays. Cant wait to put it together.
Old 05-21-2018, 01:44 PM   #6
CATCHALLBLUE
Found out you can buy electric coils now. Not sure how it works though or how its installed.
Old 05-21-2018, 01:46 PM   #7
geezer#99
geezer#99's Avatar
Might be available. Look here.
https://quadrajetparts.com/monojet-c...c-240_257.html
Or go electric.
Old 05-21-2018, 01:49 PM   #8
geezer#99
geezer#99's Avatar
Quite simple.
Bolt the bracket to the intake or carb stud and hook up the linkage rod.
Instructions come with them.
