Eat, Sleep, Drive a Chevy
Cab alignment
Hello guys, my cab is not installed straight and I need to find the best way to be sure it's on the frame in the correct position. Do you measure the rocker to frame rail or is there more to it than that? The gap between the cab and the bed is not the same on each side.
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
Re: Cab alignment
Can you find same points on each side and measure to a common point? Possible the frame is bent.
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
Re: Cab alignment
I'm sure the frame is not bent, the cab was removed a couple of years ago, I believe it's shifted or was not straight to start with.
Re: Cab alignment
I installed the cab, then the bed, then the core support then the front fenders. Leaving every thing pretty loose so that it could all be adjusted to line up with each other. I did no measuring aside from using my fingers as a gage in some of the gaps. Everything has to look good in the end when it's all together.
The bed, cab and core support all have considerable slop in the connection points so that it can all move around to suit each other. The front fenders have some slop, but not near as much as the rest of the parts. Without knowing your situation, one could guess that your bed is off and maybe your cab too. Hopefully your frame is straight.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
Re: Cab alignment
What I did...
Got the bed on the frame as straight/plumb as possible, then aligned/shimmed the cab-fenders-core as a unit with the bed using multiple floor jacks and lengths of 2x4. Hth, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
Re: Cab alignment
Awesome, thanks for the tip!
