Old 05-22-2018, 08:49 PM   #1
Cbo68
What’s this plate for ?
So just curious what this plate is for under my front engine crossmember.
Cbo68 is offline   Reply With Quote
Old 05-22-2018, 09:05 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: What’s this plate for ?
Looks like someones attempt at engine mounting plates ,
BUT my main Question would be is that Copper tubing your using for brake lines ? That's a BAD idea ! if it is just Copper your going to have to change it out to Ni-cop lines , Standard plumbing copper lines will spit under pressure
Grumpy old man is offline   Reply With Quote
Old 05-22-2018, 09:30 PM   #3
Cbo68
So the stock engine plates are installed, but someone before me for whatever reason cut them off just above the engine mount. Haven’t figured out why someone would do that yet but I have some stock replacements I found on eBay on the way. As far as I know the rest of the crossmember is stock. The plate is bolted to the bottom side of the frame thru the bolts for the crossmember and is just sticking out. I was just going to take it off because I can’t see that it is serving any purpose but figured I’d see if anyone has seen something like this before.
As far as the brake lines they are NiCop lines.
Old 05-22-2018, 10:08 PM   #4
Bigdav160
Bigdav160's Avatar
Nothing about the engine mounting appears OE. The bolt holes on either side of the brake lines are where the factory mount/crossmember bolts to.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 05-22-2018, 10:17 PM   #5
Cbo68
Like I mentioned someone chopped them off. The mount towers are attached to the crossmember then mounted to the engine and just above that someone cut them off so where they would usually continue up to the top of the frame rails and bolt. that section on both sides got cut off. Don’t know why but they did.
Old 05-22-2018, 10:28 PM   #6
Cbo68
See what I’m saying.
Old 05-23-2018, 12:11 AM   #7
kwmech
They chopped them off so the headers would fit. Unless you are going to race the truck I would eliminate the headers, put on some corvette ramhorns and get some correct engine stands. It never ceases to amaze me how these trucks get hacked up
Old 05-23-2018, 12:56 AM   #8
Cbo68
I initially thought the headers too but to me it looks like there is room still. Unless they had a different set of headers on. I’ll know for sure once I get my new crossmember. I’ve been wanting to go to ram horns anyways. I haven’t don’t much research on the corvette horns I’m guessing they are a direct bolt up?
Old 05-23-2018, 08:27 AM   #9
67c10rustbuket
67c10rustbuket's Avatar
Im guessing it’s a 2wd to 4wd conversion with wrong year parts cut to fit. Nothing wrong with a conversion just make sure it’s safe.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 05-23-2018, 09:54 AM   #10
Cbo68
This would make sense because I’ve already changed some 2wd parts to 4wd. I bought a 4x4 crossmember off the parts forum. So I should be able to just get rid of that plate once I have the correct crossmember installed? I just wanted to amake sure it didn’t serve any other purpose.
Old 05-23-2018, 11:02 AM   #11
davepl
davepl's Avatar
What on earth? Are those COPPER brake lines?
If so you need to fix the WHOA before you worry about the GO. And on this truck if it's not factory, look at it closely. Whoever was working on it before was, um, innovative.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-23-2018, 11:09 AM   #12
Cbo68
NiCop lines.
Old 05-24-2018, 12:35 AM   #13
57taskforce
All about them K’s
57taskforce's Avatar
Originally Posted by Cbo68 View Post
NiCop lines.
Nicop is good stuff it flares and bends so much nicer/easier than steel. Looks like you’ve got quite a bit of “ingenuity” there. Not sure why the plate is there but it definitely doesn’t resemble anything from my factory K20.
Tyler
57taskforce is online now   Reply With Quote
Old 05-24-2018, 01:50 AM   #14
Cbo68
I really liked working with the NiCop lines. All my steel lines were toast. So I redid the entire truck with it. It was my first attempt at doing brake lines, so I have a few short lines that were my first ones I don’t like that I’m eventually going to replace just due to the bends not looking as great as the rest. Overall tho I like them.
