Will a 88-91 dash bezel fit and 85?
I pulled a nice bezel off an 89 burb to use as a donor for my autometer guages. I later realized it has the DIN radio configuration and my 85 is the knob style. No big deal but it looks like that corner area of the bezel is slightly betterdifferent and may not follow the contour of the metal dash.
Thanks for the help. |
I'm just glad to be here!
Re: Will a 88-91 dash bezel fit and 85?
It should bolt up fine. The metal behind the bezel would have to be but to use a DIN style radio if that is what you want. You could fab up a piece of textured ABS to fill the DIN hole in the bezel if you want to keep the knob style radio.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
http://bowtieguy.proboards.com/threa...ce-bezels-fits
This may help
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
![]() Join Date: Nov 2012
Will fit 100%. Dash steel never changed other than 1.5 DIN radio opening.
89-91 is nice option if your dash has been hacked for aftermarket radio. |
