Door and front clip compatibility.
I was wondering if a 66 c10 door will fit on a 63 cab? Also is the 66's entire front clip compatible with the 63 cab?
I see that the front fenders and hood are the same part numbers but the door and door goass seem to be different between 63 and 66. Any insight would be appreciated. Thank you. Posted via Mobile Device |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: Door and front clip compatibility.
Doors are not compatible except the door skin could be reworked. Nothing else on the door will interchange except the door handles inside and out.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
Front clip would be the same except for the emblem holes.
Thanks for the info! Are the 63 and 66 chassis' the same? Would the cab and entire sheet metal bolt on to a 63 frame?
60-66 Nut
![]() ![]() Join Date: Mar 2007
The '63-'66 frames are the same except for the panhard bar bracket on the frame.
