05-23-2018, 08:41 PM | #1 |
free trans
Anybody want a SM465 trans? It came out of my 87 SWB. Swapped it for a Muncie M20. I tried to sell it on CL but no bites. Now its in my way and needs to go.
It comes with almost everything. It works fine, just not for what I wanted it to do. Only catch is if you want it you have to take everything else with it. Heres a list; trans w/shifter and boot flywheel clutch bellhousing clutch fork slave cylinder (new Luk still in the box, never used) crossmember 2 piece driveshaft w/new u-joints and carrier bearing most, if not all the hardware to mount it all I know this should go in the classified section, but I cant post there, sorry. |
05-24-2018, 07:51 PM | #2 |
Re: free trans
Go post over on ifsja.org. Jeep guys are looking for those sometimes.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
05-24-2018, 09:47 PM | #3 |
Re: free trans
Same on pirate4x4.com. They like the low 1st and beefiness.
05-25-2018, 04:26 PM | #4 |
Re: free trans
Thanks, I will give it a try.
05-25-2018, 09:05 PM | #5 |
Re: free trans
I'd take it depending on where you are
Posted via Mobile Device |
05-25-2018, 09:14 PM | #6 |
Re: free trans
Duplicate post
Posted via Mobile Device Last edited by AtomicYJ; 05-26-2018 at 05:13 PM. |
05-26-2018, 01:29 AM | #7 |
Re: free trans
I am in Mt Dora FL. It would probably cost more to ship it to you than what you could buy another one for. The trans alone is 175 lbs.
05-26-2018, 05:09 PM | #8 |
Re: free trans
In a couple months I'll be moving near Savannah, GA which doesn't look thay far away
05-26-2018, 07:01 PM | #9 |
Re: free trans
I believe its about 3 hrs away.
I just moved all of it to under my carport, so its out of my way. If you want it, its yours. I can hold it for a few months. |
05-27-2018, 11:48 AM | #10 |
Re: free trans
If its not causing you any problems I'll definitley take if after I move
