Radiator core brakets?
Is this a 1967 to 1968 bracket or 1969 to 1972 bracket and wich mounts I need. I bought the mounts for 1969 c10 but the mounts seam to high and I think I need the ones for 1968. My truck is a 1969 c10. With 1969 front clip
#2 | |
The Older Generation
Re: Radiator core brakets?
The hole in the bracket is smaller on the '67 & '68. If everything is '69 you will need the mounting kit for the '69-'72. If you don't replace the cab mounts at the same time you will run into alignment problems..... LockDoc
I did some research and I believe I installed the cab mounts backwards the thicker ones out back and the slims out front. Im going to reverse them tonight and see. I bought the polyurethane, from summit racing
