Old 11-12-2003, 12:16 AM   #1
stingray72
Red Headed Step Child
stingray72's Avatar
Attempting to crank new Crate motor
My dad has a 1972 Chevy Cheyenne that he has been working on. He's got his new engine in the truck and everything hooked up and is now trying to crank it.
He's got a Mallory magnet breakerless distributor. He's got 12V to the ignition wire when the AC is on. When trying to crank it it drops to 9V on the ignition wire. When the wire is connected to the positive side of the coil there are only 4.75V and there is no fire at the distributor. Tried 2 different coils and had no spark either time at the distributor. The ground appears to be good.
Has anyone got any suggestions to what the problem might be?
"Dinner, the perfect break between work and drunk"
-Homer Simpson
stingray72 is offline   Reply With Quote
Old 11-12-2003, 01:26 AM   #2
dinnut
dinnut's Avatar
that really has to suck. are all the grounds hooked back up? is the battery low/does it need replacing? by ac do you mean air conditiong or accessories. it spins but no fire?did you do everything right installing the distributor?
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 11-12-2003, 02:12 AM   #3
68c10owner
68c10owner's Avatar
are you still running the stock balist resister or resister wire? that will cause a drop in voltage. if you are still running it, make sure your distributer doesn`t need it. some mallery`s are a "unilight" and need the resister. the magnetic breakerless ones should`nt need it but read the instructions before disconnecting the resister.
Anthony
68c10owner is offline   Reply With Quote
Old 11-12-2003, 10:49 AM   #4
stingray72
stingray72's Avatar
dinnut - are all the grounds hooked back up? is the battery low/does it need replacing? by ac do you mean air conditiong or accessories. it spins but no fire?did you do everything right installing the distributor?
The grounds are hooked up, the battery is brand new and tests well. AC = accessories. It does spin but there is no fire from the coil to the distributor. The distributor is installed according to the instructions that came with it
68c10owner - are you still running the stock balist resister or resister wire? that will cause a drop in voltage. if you are still running it, make sure your distributer doesn`t need it. some mallery`s are a "unilight" and need the resister. the magnetic breakerless ones should`nt need it but read the instructions before disconnecting the resister.
I honestly don't know the answer to your first question but will find out. We've tried with both with the resistor and without. With the resistor there is too much of a voltage drop. We're not supposed to need it according to the documentation that accompanied the distributor (I believe).
Our only guess right now is that it could be a bad distributor. Is there a way to test them?
edit: Thanks for the help so far guys
-Homer Simpson
Old 11-12-2003, 11:43 AM   #5
tom hand
CCRider
tom hand's Avatar
If you have a meter the distributor is simple enough to test. Set the meter on continuity and connect it to the lead that goes to the coil and connect the other lead to ground. Turn the motor over with a rachet and you should get continuity in 8 places as the motor goes around. You could even use a test light by connecting one lead to positive on the battery.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 11-12-2003, 12:55 PM   #6
cdowns
cdowns's Avatar
if you're using the original wire to the distributor that's a resistor wire and should be replaced with a piece of 14ga wire to a switched outlet
Old 11-12-2003, 02:20 PM   #7
jamis
F.A.S.T. president
jamis's Avatar
Run a jumper wire from the batt. to the positive side of the dist. and coil. That would eliminate any switch or power drop probelms.
If that still doesnt work then the problem is in the coil or dist.
You can check those parts just like tom hand said, a couple of threads up.
jamis is offline   Reply With Quote
Old 11-12-2003, 02:28 PM   #8
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
This is just a remote chance, but have you checked the starter? Even new or rebuilt ones can cause problems like you are discribing if they are drawing too much amperage. That would be something else to check once you have eliminated everything else. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
