TH350 downshift question
1970 c10
350/350 auto 3:07 rear end I believe New downshift cable installed last year. Adjusted to full cable pull at wot Truck downshifts fine under 25. Also downshifts fine over 45. Question is It won't downshift at all between 30-45. Is this normal? Any way to adjust? Maybe by adding an adjusting vacuum module? Thanks for any info offered Mark
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com Last edited by rockyrivermark; 05-24-2018 at 09:54 AM. |
![]() Join Date: Mar 2017
Re: TH350 downshift question
Not sure about your question as I’ve never had one that worked. I always just manually shift if I need to. On a side not. Where did you get your new cable, I need one for my sons truck
Cable and bracket assembly from summit
Lokar was the brand
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
| Bookmarks |
