20' Daredevil (Ret)
![]() Join Date: May 2003
A/C condensor pusher fans
Had a third shop work on my A/C and it finally seems good.... with one exception. I was told I need a couple pusher fans in front of the A/C condensor, because at low speeds (or at idle) there's virtually no air passing through the condensor. It's in the stock position but sits too far from the radiator. With a big gap at the top and a smaller gap at the bottom, most air to the radiator is bypassing the condensor.
If any of you have added pushers in front of your condensor, what did you use? I searched a bunch of threads but didn't find what I'm looking for. Summit has thousands of fans and it's hard to know where to start. Thanks for any help!
20' Daredevil (Ret)
Re: A/C condensor pusher fans
Nevermind..... Found 12-inch Hayden 3680 fans locally, did some more research and decided to mount a pair of them to the condensor. They'll be triggered by the hot lead to the compressor, using a relay & fuse of course.
I have a big pusher-puller sandwiched between the radiator and compressor. Definitely helps with engine cooling at hot idle with the AC on, and the AC works, so I guess both work!
It'll still slowly climb in temp at idle on a hot day though.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible Last edited by davepl; 05-25-2018 at 10:10 AM. |
Custom Sport W/T
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
Good results with thishttps://www.ebay.com/itm/Brand-New-16-Inch-Radiator-Cooling-Fan-W-Mounting-Kit-1500CFM/122349081088?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
