Rear spring hanger
Where can I buy the piece that bolts to the frame that holds the front of the rear spring? I have one that needs to be replaced on my truck.
Re: Rear spring hanger
How urgently do you need one? I am going to be removing a set of hangers from a rust free frame from GA in the future - but it may be a couple months before I take them off. I am also in Iowa - NC IA.
Make sure the set-ups are similar. There are slight variations between 2wd/4wd/C10/C30 etc....
LMC has them for the 4wd trucks. I think that may be the only place.
The ones I will have are from a 87' Short Box C10 2wd.
