Suburban Driveshaft Question
Do K10/K20 Suburbans use a 1-piece or 2-piece driveshaft? All the 2WDs I've worked on had a 2-piece driveshaft, but the intermediate shaft is pretty short. I'm wondering with the extra length of the transfer case, did 4x4 Suburbans just use a 1-piece rear driveshaft from the T-case to the rear axle, or a really short intermediate shaft?
86 Chevrolet K20/30 Suburban - 8.1/NV4500/NP205/Dana 60/14 bolt FF, build in progress 73 Formula - 400/Doug Nash 4+1, resto on hold 86 Chevrolet K30 3+3 - 350/TH400/NP241, Air Force/Forest Service Rescue Truck, for sale 01 Ram 2500 - 5.9L Magnum, daily driver 91 BMW 325i - Chumpcar series racecar |
Re: Suburban Driveshaft Question
My 1982 C10 Suburban has a 1 piece driveshaft.
Post Whore
![]() ![]() Join Date: May 2015
4x4 2500 burb has 1pc d-shaft...
My '91 V2500 4WD Suburban has a one piece rear driveshaft. With 4WD, the rear shaft is shorter so there is no need for a longer shaft with carrier bearing. This 4WD drivetrain is much smoother than my older RWD '74 Suburban, where I had to replace the carrier bearing and take the shafts to a drivetrain shop for professional balancing and to replace the u-joints.
I had a hammering vibration develop under no load at 45mph recently and inspected both driveshafts; when researching online I found an answer to a worry I had about the front driveshaft. It is splined so that it can move forward and backward when turning or going over bumps, and there is a grease fitting which I lubed, along with all the other front end parts accepting grease. I was investigating why when you don't have 4WD engaged the front driveshaft can rotate back and forth about 1/16" of a revolution. Jeep and 4-runner forums said this is completely normal and don't worry about it. If there is any up and down slop in the differential yoke or the transfer case then you have a problem. My vibration problem turned out to be old worn out tires that were letting go all at once, internal belts were separating and banging on them with a wood block and sledgehammer to free them from the hub (due to rust) probably didn't help matters. I had Big O tires put it on a lift to make sure the drivetrain was ok, it was only $65 for a half hour diagnostic check to rule out any drivetrain problems. I was on the right track by starting to swap in another tire set I had and the problem improved with the first tire I put on. Thought I would reply to this thread, aptly named, and mention the small, expected rotation of the front driveshaft when 4WD is not engaged, in case anyone searching these boards is wondering about that. |
All 4wd Suburbans had a one piece shaft.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Thanks for the help gents, exactly the answers I was looking for.
Negative. My 78k20 burb with a 465/205 and a 14bff had a 2 piece.
Factory. |
Dang it.
"All auto trans 4wd Suburbans had a one piece shaft". K
#9 | |
Interesting though, as a 205 is where I'd like to end up with mine. Guess I'll need to hang onto the two-piece setup after all.
465/205 with a slip yoke rear outputs have a 1 piece rear shaft..
465/208 come all with a slip yoke rear output as well. 1 piece rear. |
