wiring question
![]() 4 wires come out of this harness under the cowl. Purple and Yellow #1 were clearly marked "r" and "S" for the solenoid. Green and yellow #2 were not labeled and have different ends on them. Green has a heat wrap on it. Where do these go? Thanks. |
Re: wiring question
Green sounds like the temp sensor in the head. Yellow suggests the wire from the not S terminal on the solenoid to the coil. Since there's an HEI in the pic, the yellow isn't used.
There's a wiring diagram on this site if you want to look a little. |
Re: wiring question
I put the HEI in. I was going to come straight off the ignition switch to power it. That means I can just abandon this yellow wire then?
Thanks. |
![]() Join Date: Mar 2017
Re: wiring question
You don’t need the yellow wire with the hei. Tape it up or follow it back to the harness and cut it is what I would do.
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
Re: wiring question
Make sure to take the yellow wire off the "R" terminal on the starter solenoid, just to make certain that something crazy doesn't happen later.
#6 | |
The Older Generation
Re: wiring question
I run all of my HEI's off of the "IGN UNFUSED" terminal on the fuse block. LockDoc
Re: wiring question
Yup. I learned that fix right here on this board. I had done it with a solenoid before that.
| Bookmarks |
