Old 05-26-2018, 10:06 PM   #1
rvrfoot
1966 c10 mirror location
I got repos doors. I did not look at my old doors before i sold them. I need to know the measurement to the center of the bolts?
rvrfoot is offline   Reply With Quote
Old 05-26-2018, 10:56 PM   #2
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: 1966 c10 mirror location
I think a template was posted here in these forums.
I'll see if I can find it.
66 C20 Service Truck:
Old 05-26-2018, 11:02 PM   #3
LostMy65
LostMy65's Avatar
I guess it was for a 61-63:
http://67-72chevytrucks.com/vboard/s...ghlight=Mirror
I'll keep looking.
Old 05-27-2018, 06:53 AM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Hi rvrfoot, the only thread I can find on that you already posted on last year.
http://67-72chevytrucks.com/vboard/s...d.php?t=685694
It's the actual measurements of the holes is what you need. If you have time I can make a template and send it to you of the drivers door, then just transfer to the passenger when ready. I don't have my door mirror on yet.
Old 05-27-2018, 09:09 AM   #5
The Rocknrod
Moderator
Sent you a PM.
Old 05-27-2018, 10:10 AM   #6
rvrfoot
Sent back thanks.
Old 05-27-2018, 06:07 PM   #7
DLW
Can you send me that as well please?
PO welded all the holes up for my driver side door so I can't copy anything over either.
Thanks,
Dan
DLW is offline   Reply With Quote
Old 05-27-2018, 07:02 PM   #8
TopFuel1966
TopFuel1966's Avatar
There should be a triangular shaped reinforcement with 3 captive nuts spot welded to the inside of your drivers side door where the mirror mounts. Try to use that to recover your holes for the correct location.
TopFuel1966 is offline   Reply With Quote
Old 05-27-2018, 08:17 PM   #9
The Rocknrod
Moderator
You'll have to get rvrfoot to send it after I send it to him.
Old 05-27-2018, 09:53 PM   #10
rvrfoot
Thanks, I will send it to him after i am done.
Old 05-27-2018, 10:15 PM   #11
Macdaddy1
I to need the template as I recently had to purchase new doors and need to mark the mirror holes.
Pat
Macdaddy1 is offline   Reply With Quote
Old 05-27-2018, 10:26 PM   #12
Macdaddy1
That would be great.
Old 05-27-2018, 10:38 PM   #13
rvrfoot
Pat
Sorry i ment dlw.
Old 05-28-2018, 08:45 AM   #14
ImpalaJim
ImpalaJim's Avatar
reproduction doors do not have that!!
ImpalaJim is offline   Reply With Quote
Old 05-28-2018, 12:48 PM   #15
TopFuel1966
I'm sure that repro doors don't, but DLW mentioned that a PO had filled in the holes in his doors.
Old 05-28-2018, 05:26 PM   #16
DLW
You might be right about the stock nuts still being there on my truck, although welded over. I will keep that in mind to make a template from inside the door if possible. If this template Rocknrod made is accurate though, it might be nice to have and easy to make more of them. Surprised there is no template out there yet for 64-66. I think we need to find a way to get that template, or another one like it, in PDF that prints in real size so you don't have to physically mail it around.
Old 06-01-2018, 08:57 PM   #17
rvrfoot
Sent you a PM.
Got it today thanks.
