want discs, confused
i have 4 wheel drums. want front discs. if i buy drop spindles, new 6 lug rotors, and new calipers... can i keep the 70 ball joints? anybody done waht im thinking of...? whats the best/cheapest way to do?
in case you havent noticed. i like lowered trucks. this truck is not mine but is sweet
70 longbed 496/th400/Ford 9" |
if you buy the drop spindle kit for your year truck you should be fine.
Anthony |
Pronounced "Pew-al-up"
I have that truck on my desktop at work!! Sweet!!!
Thats the grill setup Im gonna buy, when I have the cash! ![]()
Classic GM Trucks of Washington Club Member 1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's, Power Locks, Truck Photos |
Progress = 0%
You might consider switching to 5-lug discs since there is a much bigger selection of 5-lug wheels. So one day when you want to put some "bling bling" rims on your truck, you'll have have a lot to choose from
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra |
chevelito
sup dinnut...you might want to read the fine print on some of the disc kits because I think cpp uses 73 and up ball joints. the ones that mcgaughy has (which many of the vendors here carry) you can use the 67-71 ball joints. just my .02
ditto what slammed said.
New deadline...when my son can drive. ![]() Aloha from Honolulu, HI |
Member since 2000
Early classic make spindles for 70 so it's a direct bolt on.
![]() Join Date: Mar 2000
Dinnut we stock the complete bolt in spindles that use all your original steering and suspension hardware that allow you to install disc brakes. You can check them out on our site here
http://www.gmcpauls.com/Brakes&Steering.htm If you have any questions on doing it give us a call or drop us a email we will be happy to help!!! We broke the kits down to so you can purchase it in stages or all at once depending on budget. GMCPaul |
I bought this kit from Paul and was/am very happy with it. I went ahead and bought the springs and all. It is not hard to do!
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
Low & Slow
If you go ahead and go with a 6 lug kit, If you decide later that you want 5 lug you're only out the cost of rotors. Oh and wheel bearings. I went with the 6 lug kit fro mcgaughy's. It is a direct bolt in.
70' C-10 LWB Fleetside 4.5/6 drop ![]() |
97' Tahoe 2dr/2wd
i used the kit from GMC PAUL'S
worked good, haven't dropped it yet $$$$ but sometime in the future |
71 DELUX
CPP
I used CPP spindles which do come with new upper ball joints and new tie rod ends, that are 73 up versions, a bit bigger and beefier. It was the best bang for my buck, as I not only got the spindles but other new front end parts.
Dinnut, I bought the Early Classic because it came with everything including master and prop valve, which nobody else included. There were cheaper kits out there, but man those guys know what they are doing and they helped my cousin and I out when we had questions on a Saturday morning.
#13 |
sweet... thanks gmc for the link... i want 6 lug because i like 6 lug rims. they have some sweet ones out there and i want to be different.
gmc paul... i may have to email you about this. but what is the big difference in the 470 and 240 dollar kits... as far as i understand i wont have to change much with the 470 dollar kit... which is good. and it comes with dropped spindles too... i may have to get that. what would i have to do for a master cylinder/prop valve? would i be able to use a 71-72? or woudl the stock setup work, even though im pretty sure it doesnt. any help would be helpful
#14 |
hehehe. see where im coming from? billet specialties baby.... lots of cool looking 6 lug rims out there
#15 |
ttt
#16 |
dinnut, the $240 kit is used by people buying the kit in stages as the money becomes available then they purchase the spindles and adjustable prop valve or spindles & booster master cyl. combo with a brake prop valve at a later date when more money becomes available. With the $470kit you can buy just the adjustable prop valve and stick it below your current master cylinder distribution block and then you will not need to swap master cylinder out to disc/drum style, you can however use the 71-72 master cylinder / prop valve if you prefer, or we also offer the 7" & 9" booster master cylinder combos and a disc brake prop valve. The advantage to using the 7" booster combo is this booster only requires 16lbs of vaccuum to operate and a 9" only requires 14lbs so those with higher lift cams that produce far less vaccuum available from motor still can have power brakes, unlike the 71-72 stock booster which is designed for 18-20lbs of vaccuum depending upon style of stock unit. The adjustable prop valve is nice as it allows you to change the brake line pressure bias from front to back by the turn of a knob allowing you to dial in the front to rear brake bias exactly to your truck and weight conditions, the standard disc/drum prop valve we sell performs just like a stock one with no adjustability to it.
Really far easier to explain all this by phone or in person as the postive & negative factors can be gone into in more detail on each style of set-up. Basicly though the $470 gets you everything needed to put disc brakes on your truck without having to change any ball joints, tie rod ends etc.... such as with a CPP kit or some of the others, and to optimize front to rear braking bias you need only decide if you prefer to go the adjustable prop valve route, or the disc/drum master cylinder route with a disc/drum prop valve. Gives us a ring or email we'll be happy to help. GMCPaul |
#17 |
wow. thnaks for the explanation. thats a lot of thinking for me to do. 500 bucks is a lot, but not alot compared to some of the other kits. i need the emergency brake/parking brake to work before i can get an inspection because it doesnt work. i think this means the brakes are going bad. i dont want to sound stupid but: are the parking brakes built into the front and rear brakes or just front or just rear?
#18 |
chevelito
just rear
#19 |
oh. ok. parking brake in rear... id like discs in back too but 600 is a bit out of budget (im way poor, remember?)
#20 |
My other Love
I went with the early classics set-up, i got the 2.5 drop spindles, nice kit used orignal ball joint (of course I changed them) it also came with brake booster and proportioning valve, nice setup and I was able to retain my ralley wheels without any problem
![]() Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
#21 |
Life, Be In It.....
![]() Join Date: Oct 2003
Some grerat ideas and great trucks
#22 | |
Merciless Butcher
rear brake cables
Your Bought And Sold....I Got Your Soul! |
#23 |
what about the parking brake? is it the same as the emergency brake? i sound stupid i know. but i would like to fix this problem. i have a floor shifter and a crappy one at that. th350. what activates the parking brake? or is it the same thing as emergency brake?
#24 |
chevelito
parking and e brake is the same. usually engaged by a foot pedal or in 67-68s a hand brake.
#25 |
oh. my parking brake doesnt work like at all. i cant park on any angle or ill roll. it wont hold it at idle or anything. i really want discs. any chance of gettgn a board members discount gmc paul?
