Old 05-28-2018, 05:55 PM   #1
CATCHALLBLUE
CATCHALLBLUE's Avatar
Gremlins...help!
Hey yall...Just fired up the 69 c30 292 for the first time in 5 years!!!!
List of parts changed...
1. Whole new fuel system including tank, sending unit, fuel lines, fuel pump, fuel filter and carburetor.
2. Master cylinder and brake booster.
3. Wheel cylinders in the front.
4. Brake pads and various drum break components that were missing or seized.
5. Rubber break lines in the front.
6. Radiator
7. New battery
8. Plugs, wires, distributor cap and rotor
Topped up the differential and bled the breaks and Voila shes back from the dead! Took about 4 weeks total to put her back together.
Not sure why but everything rusts super fast out here so I also put a couple coats of flat black on the master cylinder and booster.
OK now to the gremlins. The rear lights stay on with the key out of the ignition. Seems like a simple problem but wondering if its a common problem on these old trucks. Disconnecting the battery every time is fine. I like lookin at her inside parts. Shes purdy!
Ill see if i can figure out how to post pics from my phone in a minute.
CATCHALLBLUE is offline   Reply With Quote
