Old 05-28-2018, 10:47 PM   #1
MiraclePieCo
MiraclePieCo's Avatar
Does this belong on an AD?
I purchased my truck as a basket case (what is it with people who disassemble a perfectly good vehicle, throw all the parts in boxes, then go off and leave it until half the parts are lost?). Anyway I found this piece I don't recognize and I'm not sure if it belongs on my '51 panel truck or if it's just some irrelevant part off of something else. Do you recognize it? What is it? Where does it go?
MiraclePieCo is offline   Reply With Quote
Old 05-28-2018, 11:07 PM   #2
68blackbird
68blackbird's Avatar
Re: Does this belong on an AD?
Rag joint?
Kel's 1950 GMC 1/2 ton build
68blackbird is offline   Reply With Quote
Old 05-28-2018, 11:48 PM   #3
NorCalGal
NorCalGal's Avatar
Yep, Blackbirds right that's the rag joint off a steering box. Minus the rag. lol
Jan's 53
NorCalGal is offline   Reply With Quote
Old 05-29-2018, 12:06 AM   #4
MARTINSR
MARTINSR's Avatar
And the answer is NO it did not go to the truck when stock at least. This is a "rag joint" that connects the steering column to the steering box on a later car or truck. The original AD truck had a one piece assembly of the steering box and column so no rag joint was used. The column is bolted to the steering box and the shaft the steering wheel is hooked to goes right into the box with the worm gear on it.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 05-29-2018, 04:31 AM   #5
MiraclePieCo
In the trash it goes, lol. Thanks!
1951 Chevy Panel Truck
