Old 05-28-2018, 11:32 PM   #1
riz
how to compress drop springs??? Need help badly.
I have McGaughy drop springs and I can't get them compressed enough to install into my POL tubular lower control arms.... I tried using a compressor with the pickle fork looking part but it won't fit fully into the dropped tighter coils....so it won't align in the middle of the coil.......... is there a different type of compressor? I'm thinking of making my own somehow but not sure how.
The reason I need to get these in ASAP is that I need to get the truck as a roller so I can get it out of the garage by June 9th for my daughter's grad party..... I really need to get these installed fast.
Any and all help is greatly appreciated.
RIZ
81 C10 short box
82 K5 Blazer
riz is offline   Reply With Quote
Old 05-29-2018, 12:26 AM   #2
bilfman
bilfman's Avatar
Re: how to compress drop springs??? Need help badly.you
Have you tried using the weight of the vehicle? That was an old school technique, hyper extend the suspension, stuff the spring in place and slowly use the weight of the vehicle to compress it enough to assemble everything.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 05-29-2018, 02:03 AM   #3
riz
its just a bare frame right now so I'm sure that's part of the problem......not sure how to compress it enough to try that???
RIZ
81 C10 short box
82 K5 Blazer
Old 05-29-2018, 06:28 AM   #4
bdiamond
Use a ratchet strap or two and do it the way bilfman was talking.
bdiamond is offline   Reply With Quote
Old 05-29-2018, 10:08 AM   #5
Bloodhound
This was the battle I had, especially using stock height springs. None of those type of spring compressors would work. I finally found one that did work, but it isn't cheap! But it worked perfectly. I'd lend you mine but you're about 1500 miles away.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Bloodhound is offline   Reply With Quote
Old 05-29-2018, 11:14 AM   #6
I used my 10-ton press. Large plate, then compressed them...held them together with ratchet straps. until the spindles/ball-joints were secured.
Old 05-29-2018, 05:27 PM   #7
Tom
driving is in my blood
Tom's Avatar
I always just pushed down on the a-arm while pushing in the spring. Using a lowered spring it shouldn't be a problem at all.
Old 05-30-2018, 01:40 PM   #8
wahl4m
sometimes a chain can be attached to a floor jack -under the lower "a" frame & looped up over the upper "a " frame ?or hook the chain somewhere on the frame & that will hole the vehicle -while you jack the lower arm up?? watch for flying parts if something comes loose ?? its should be relative easy ?? good luck !
wahl4m is offline   Reply With Quote
Old 05-30-2018, 02:59 PM   #9
truckin 79
Use a standard coil spring compressor but take one of the ends off. Feed the threaded end through the shock tower upper mount and other end with fingers to spring. Of course you would use a bolt with some washers on shock mounted side. Slowly tighten bolt and compress spring, it worked for a guy who was working with on a Trans AM
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 05-30-2018, 04:31 PM   #10
truckin 79
Opps I just forgot a TA and truck shocks mount different
Old 05-31-2018, 07:45 AM   #11
calvin78612
calvin78612's Avatar
Worked fine for me
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 05-31-2018, 08:32 AM   #12
riz
I'm trying to compress the drop spring so I can install it.
RIZ
81 C10 short box
82 K5 Blazer
Old 05-31-2018, 10:46 AM   #13
calvin78612
That's what the Jack does
84 step side
87 swb
Old 05-31-2018, 11:34 AM   #14
calvin78612
This is with no weight on wheels. Disconnect lower ball joint, set spring in pocket. Use strap setup and jack to compress spring.
84 step side
87 swb
Old 05-31-2018, 03:08 PM   #15
Tom
Tom's Avatar
That's the confusing part. Every drop spring on multiple trucks that I've installed were shorter then oem and so didn't need any compression to be installed. You literally push down on lower a arm slightly and set spring in.
Old 06-01-2018, 07:59 AM   #16
riz
I keep hearing that but the springs still won't go in as I do just that. They keep sliding out of the lower control arm pockets.
RIZ
81 C10 short box
82 K5 Blazer
