Old 05-29-2018, 01:47 AM   #1
Cheyenne350
Fuel lines and fuel pump wiring help
Using a gas thank out of 98 Camaro z28 and I'm a bit confused on what line is the sending and which is the return. Just to double check on the wiring the GREY wire is the power/ PURPLE would go on the fuel gauge/ BLACK is ground but what would be the other ground with the white line be too. Thanks in advance.
[attach]Name:  45.jpg
Size:  72.2 KB[/attach]
Cheyenne350 is offline   Reply With Quote
Old 05-29-2018, 10:22 AM   #2
dec010974
dec010974's Avatar
Re: Fuel lines and fuel pump wiring help
yes. you are correct.
dec010974 is online now   Reply With Quote
Old 05-29-2018, 10:47 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Is one the pump ground, and the other the gauge ground? Fuel gauges work on resistance to ground, so power goes from your gauge +, to the sending unit PURPLE, and the other black to ground, and the sweep of the arm creates resistance across that ground giving you a level.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
