Old 05-29-2018, 05:09 AM   #1
hdixon
Cab doors
Hey guy's can anyone help me understand why I have slam my doors so hard for them to close after installing new rubber door seal and new door bumpers. before installing the new rubber door seal the doors closed ever so easy. Are they normally hard to close after installing new rubbers? Did I install them incorrectly? I really have to slam the doors very hard now to closed them. Do I need to leave the doors closed for a few days against the new rubbers will they form into the right position? any help would be great.
hdixon is offline   Reply With Quote
Old 05-29-2018, 06:49 AM   #2
panhead59
Re: Cab doors
This seems to be a common issue. Most just leave truck in sun wiith doors closed for a few days. This seems to help. Problem should go away or at least be tolerable after some time. Nothing you did wrong. I am getting ready to install new seals and will use some made by "soft seal". Some here say problem is at least much less with this brand. I'll post my results soon.
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom)
1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK.
1968 Chevy Custom SWB pick up. Fleetside. Lowered 4/6. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive !
panhead59 is offline   Reply With Quote
Old 05-29-2018, 07:08 AM   #3
Redneck Rydes
Redneck Rydes's Avatar
Re: Cab doors
Just put new ones on mine, same thing,they will soften up in time,I also moved my strikers out a little bit,worked really good.
Redneck Rydes is offline   Reply With Quote
Old 05-29-2018, 10:13 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Re: Cab doors
Like Redneck said you can move the striker plates out a little bit. Mark around them with a fine felt tip marker so you can tell how much you have moved them and move them out about 1/16 inch at a time. Don't let them move up or down, just out.
LockDoc
Leon
Old 05-29-2018, 12:12 PM   #5
hdixon
Re: Cab doors
thanks everyone for all you help I will give it a try and reply on the results
Old 05-29-2018, 01:15 PM   #6
Hart_Rod
Hart_Rod's Avatar
Re: Cab doors
A little ArmorAll on the seals and door edge help too...
Hart_Rod is offline   Reply With Quote
Old 05-29-2018, 01:26 PM   #7
hdixon
Re: Cab doors
thanks you I am willing to try anything at this point I am still putting the truck back together so I can't move it out in the sun no motor yet just got the cab back from the body shop and trying to put things back together again
Old 05-29-2018, 05:42 PM   #8
RenoKeene
Florida Edition
RenoKeene's Avatar
Re: Cab doors
I basically just took a 2x4 and hammer and bent the pinch weld in a bit. This was before I put the vinyl on. Took some overall tweeking but doors close and seal good. I probably spent 8 hrs on each door to get them right so it takes some patience.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
