05-29-2018, 09:47 PM | #1 |
Transmission High-Hump Gasket Seal
Is there a gasket to seal the transmission hump to the floor pan? If not, what to use for sealant?
05-29-2018, 10:39 PM | #2 |
Re: Transmission High-Hump Gasket Seal
Lay a good [~5/16''] bead of RTV, then lay wax paper over it -- so it only sticks to one side. Attach top panel on loose, but even, don't go all the way tight. Let cure 24 hours. Later, peel up wax paper, and bolt down. Should yeild a good water-tight seal that is reusable.
05-29-2018, 10:48 PM | #3 | |
05-30-2018, 04:02 AM | #4 |
Happy to help, my Friend.
05-30-2018, 01:05 PM | #5 |
That is an awesome idea! I am replacing mine currently and bought the RTV last weekend. Thanks for sharing the tip!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
05-31-2018, 06:06 PM | #6 |
i like that tip...
1972 Chevy C10 400sbc 4sp Matthew 4:19 And he saith unto them, Follow me, and I will make you fishers of men. |
