Old 05-30-2018, 09:48 PM   #1
6768chevylover
6768chevylover's Avatar
Wilwood sucks?!
I had installed the d52 calipers on my 71 blazer 4wd. I Think They work great when they work. My issue is that my one caliper seems to be partially seized. I can move the piston in with a C clamp. Then I can install it back on and step on the break, then the caliper will not release from the rotor once I release the pedal. Any ideas on why this is happening? Thanks, Mike
6768chevylover is offline   Reply With Quote
Old 05-31-2018, 11:59 AM   #2
71cheyennesuperlongb
71cheyennesuperlongb's Avatar
Re: Wilwood sucks?!
Did you replace your rubber brake lines? Sometime they break down inside and block the fluid from returning.
'71 Cheyenne Super LWB - Second Owner in 39 Years!
'70 CST/10 SWB - Soon to be Daughter's truck when finished
71cheyennesuperlongb is offline   Reply With Quote
Old 05-31-2018, 12:39 PM   #3
6768chevylover
Re: Wilwood sucks?!
I have braided lines instead of rubber. They are only about a year old. That could break down that easy? I'll try replacing them..
Old 05-31-2018, 09:09 PM   #4
6768chevylover
Re: Wilwood sucks?!
Now that I'm thinking of it. Everything but the Proportioning valve is about a yr old. The valve I believe might be original. Do pro valves go bad?
Old 06-04-2018, 08:17 AM   #5
robnolimit
robnolimit's Avatar
Re: Wilwood sucks?!
D52 have 2 pistons. Do both lock up or just one? If it's just one, it's only the caliper. If both, loosen the bleader screw and see if that lets the piston go back. If so, it's a fluid problem. If not, it's a caliper problem.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
