Old 06-01-2018, 02:12 PM   #1
44boggers
GM 8.5" rear end spline count
Hey guys,
I need to order up a truetrac and new gears. Did our trucks all come with 28 spline count shafts? I had it apart two years ago and I can't remember. I feel like it was 28 spline. I think from 1989 and up is the 30 count spline. Can anyone confirm?
I know I'm being lazy by not pulling it apart, but I'm in paint and body work mode now and dont need extra oil around the small garage at this point.
Paul
44boggers is offline   Reply With Quote
Old 06-01-2018, 09:52 PM   #2
87Flh
87Flh's Avatar
Re: GM 8.5" rear end spline count
Should be 28. Only one way to know for sure though.
87Flh is offline   Reply With Quote
Old 06-03-2018, 11:07 AM   #3
determined
You are correct but given how many complete diff's I have swapped into those trucks over the years I would not take the chance ordering the parts without checking it first.
Good chance you are going to need an axle, speedy sleeve or an offset repair bearing or two.
Check it over and do it once.
determined is offline   Reply With Quote
Old 06-04-2018, 11:27 AM   #4
44boggers
Yeah I needed to stop being lazy about and just do it. 28 spline count it is.
Thanks for the motivation guys
Old 06-05-2018, 02:27 PM   #5
Jay2Cor517
Jay2Cor517's Avatar
If you decide to go the TrueTrac route you WILL HAVE TO order 30 spline count axles. https://www.summitracing.com/search?...ord=DTL913A481
Everything that can be counted does not necessarily counts; everything that counts cannot necessarily be counted--Albert Einstein
Jay2Cor517 is offline   Reply With Quote
Old 06-05-2018, 03:03 PM   #6
44boggers
https://www.summitracing.com/int/par...a556/overview/
This is for a 28 spline 10 bolt 8.5"
Old 06-05-2018, 07:59 PM   #7
Jay2Cor517
Jay2Cor517's Avatar
(Open mouth and insert foot or keyboard) Good catch 44boggers, I stand corrected. I simply should have stated the obvious, the 30 spline axle is stronger and would probably be a better choice for those who decide to change the ratio from the 2.73 to a 3.73 or numerically higher gear set with performance mods--more horsepower, bigger cam, trips to dragstrip etc.
Old 06-06-2018, 12:49 AM   #8
44boggers
Yeah I duly understand. Normally I would have done this but I have a different situation than most. I’m building this in Europe so I am relying on people to bring parts over to me since shipping plus inport fees are crazy high. So asking to bring some axle shafts on top of the locker and gears and all my other stuff is not really possible. I won’t have Crazy hp either as it’s a build 305 with power numbers probably in the low to mid 300’s and torque not any higher.
But you are correct. 30 spline axles would be better.
