Would Fesler billet flush lenses fit with my Digi-Tails LED boards?
I love my Digi-Tails LED tail lights, especially with the sequential feature on. However, they don't look as good as they could given the stock lenses having different patterns in the top (tail lights) and bottom (refelctors). They'd look better with a lens that is the same look throughout. The only lenses I know that have a consistent pattern throughout are the Fesler lenses.
However, as I understand it the Fesler lenses have a thick surround where they fit into the light housing (and the housing corners need to be trimmed). The Digi-Tails circuit boards leave a good deal of room around the edges, but is this enough so the Fesler lenses can fit? I've attached a photo of the Digi-Tails boards installed with the lens removed.
1965 Malibu SS L79 Restoration Page 1965 Two-Door Wagon Project Progress Page 2006 Pontiac GTO Preservation Project Rich Cummings |
Re: Would Fesler billet flush lenses fit with my Digi-Tails LED boards?
Anyone?
![]() Join Date: Feb 2004
I don't believe the corners are the issue. It's the depth of the reflector inside of the Fesler lense. Its shallow and the factory housing has a raised portion and leaves no room for the thickness of the board. Custom tail housings like mine should allow the board to fit.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
#4 | |
In the photo of the custom made housings you have posted in another thread they didn't look any deeper than the stock ones. Can you perhaps post up additional photos of them? TIA!
Look again at the picture....the backs of mine are flat where the led panel back would fit against. The stock housings have a bubble in the middle and the seal goes around it. That bubble is about a 1/8 " of clearance that you gain with the flat back the Fesler lense has many 1/8 -3/16 clearance. It's not much. They have a double lense in them clear read outside and clear deflectors on the inside.
