Blue (Ford) orifice tube for better cooling
Hey Guys
My 80 has a factory A/C that was originally R12 Freon now 134 the A/C compressor is a Sanden. I read that running a blue orifice tube will make the system cool better. The condenser is designed for R12 and the smaller orifice in the blue .067 compared to the OEM GM white tube is .072 will hold the Freon in the condenser longer allowing it to drop the coolant temp better. System currently runs 45 degrees at the vent. Anyone ever tried this? Thanks |
Re: Blue (Ford) orifice tube for better cooling
I've never heard that one before. Did you convert the trucks ac to r134? Did you notice a difference? When i converted my truck all i changed was the freon and oil. There was no noticeable drop in performance on mine
1986 Custom Deluxe 10 1978 Caprice 2 door - sold 1937 Chevrolet 2 door sedan - project |
![]() Join Date: Jun 2016
Over on the AC forums at ackits.com, the blue orifice tube is discussed and recommended frequently on systems that have been converted from 12 to 134. I know the system in my CC dually works well enough to make it uncomfortably cold even in Phoenix.
That being said, if you are getting 45 at the vents, I wouldn't open the system just to change the tube.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
Is the Ford blue tube a true
"drop in" replacement. Otherwise, are the dimensions exactly the same as the white OEM Chevy tube, except for the orifice size? |
#5 | |
Moderator
![]() Join Date: Oct 2008
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Yes.
This is what I was thinking as well. That's pretty good.
