06-04-2018, 09:09 AM | #1 |
Tire size?
I spent some time looking thru the tire and wheel post trying to see if I could answer my own question, but I'm still not sure. So I'm sure someone here probably knows what would be the widest tire I could put on a stock 15" rim on a 66 c10? I'd like to get away from the skinny tire look, and have some lowering dreams in my near future. Not slammed but probably 3-4 in the rear and front, enough to level it out.
06-04-2018, 11:51 AM | #2 |
Re: Tire size?
step or fleet side?
06-04-2018, 12:45 PM | #3 |
Re: Tire size?
Sorry. Lb fleet.
06-04-2018, 12:46 PM | #4 |
Re: Tire size?
275/60/15 rear, 235/60/15 front, went 225/70 front to match new 245/45/18 size.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
06-04-2018, 08:20 PM | #5 |
Re: Tire size?
06-04-2018, 08:33 PM | #6 |
Re: Tire size?
If you don't mind cranking that big tire. Or 255s all round
06-04-2018, 08:43 PM | #7 |
Re: Tire size?
I just put in power steering .
06-04-2018, 10:37 PM | #8 |
Re: Tire size?
I have 255/70 15s all around on squarebody rallys, and although my truck is still at stock height, the tires fill up the fenders well, and I am fairly certain I could easily clear a 2 inch drop in the front with no issues. The rear might need a little bit of lip rolling to clear once lowered, but I've loaded it down with some rock and didn't have any rubbing issues.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
06-05-2018, 10:45 AM | #9 |
Re: Tire size?
You really shouldn't put 275/60's on a stock rim. You would need a 7 or 8" rim and I would probably say 7 is a but undersized. You need to talk to your local tire shop and they will tell you what you can put on a stock rim.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
06-06-2018, 08:26 AM | #10 |
Re: Tire size?
yea 275 to much for a 7
06-06-2018, 11:13 AM | #11 |
Re: Tire size?
Thank you for all the replies. Sounds like I'll just wait to upgrade rims and tires at same time. Are there any specific years or models that would match up with stock equipment that would fit my bill?
06-06-2018, 12:09 PM | #12 |
Re: Tire size?
I have 73 87 8in rallies with 275/60/15s
06-06-2018, 12:18 PM | #13 |
Re: Tire size?
I have 8" rims. Front is 255/60 and the rear is 275/60/15's. Also with a 3/4 drop. The truck was converted to 5 lug but they do make six lug steels now.
06-06-2018, 02:43 PM | #14 |
Re: Tire size?
Hevy:
I'm running 275's on my 63 short fleet. My truck is lowered 4/6. As you start to push the envelope on tire width, you will need to watch your wheel backspace. I run a 4.75" backspace wheel to get it all to fit. I believe that the steelies are around a 4" backspace. |
06-06-2018, 06:19 PM | #15 |
Re: Tire size?
Yes, the 275 is a bit much for a 7" but thats what I ran. Side by side 275/60/15- 295/45/18
06-07-2018, 07:01 AM | #16 |
Re: Tire size?
Is a stock rim even 7"? I'm thinking it's like 5.5 no?
06-07-2018, 03:54 PM | #17 |
Re: Tire size?
I had 275/60 on a 15x7 rim and never had a problem
06-08-2018, 12:19 AM | #18 |
60-66 Nut
Re: Tire size?
Yes the wheels that are original to these trucks are 5.5" wide.
06-08-2018, 11:30 AM | #19 |
Re: Tire size?
06-08-2018, 01:30 PM | #20 |
Re: Tire size?
Yeah a little. But all good info for me so I can figure out what size I need to get the look I'm after. I don't really want to put any fancy rims on it, other than maybe a set of old school cragars, so I think the cheapest way is to find a later model set on Craigslist or something like that, that someone is getting rid of. Is the 6 lug pattern standard size? And what years might fit my '66? I need to do some more research I think.
06-08-2018, 02:19 PM | #21 |
Re: Tire size?
I have a set of GM "four nub" steel wheels sitting in my garage. I measured them at 8" wide (inside lip to inside lip), and they have the space to clear disk brakes. They were not stock to our trucks, but definitely have the stock look.
