06-04-2018, 01:44 PM | #1 |
My New Ride
72 454/350/373, PS,A/C, Butternut Yellow. Last edited by rdc72; 06-04-2018 at 01:56 PM. |
06-04-2018, 01:45 PM | #2 |
Re: My New Ride
I like it! More details please.
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White 1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White. |
06-04-2018, 01:54 PM | #3 |
Re: My New Ride
Thanks, I really don't know a lot about the back ground of the truck, but I have been looking for one for over 25 years, and then you find, then life happens, but I got one know. it has buckets seats, console. vintage a/c, 18/20 wheels, lowered 4 in the front rear unsure? next is relocating the gas tank to the rear and rear disk brakes. has a transmission leak that I nee to address as well. the color is butternut yellow, white top.
06-04-2018, 02:07 PM | #4 |
Re: My New Ride
Good looking truck you found. I’m surprised it has a 350 backing up a 454.
06-04-2018, 02:08 PM | #5 |
Re: My New Ride
Nice Ride! Welcome!
06-04-2018, 02:14 PM | #6 |
Re: My New Ride
Thanks guys, I was surprised myself, most would have a 400, but who knows whats been in this thing? thinking of going with a 700r4?
06-04-2018, 02:16 PM | #7 |
Re: My New Ride
If you go 700R4, get two of them. That way you have one waiting to go in after you blow it. You can then rebuild and just rotate them.
06-04-2018, 03:23 PM | #8 | |
Re: My New Ride
Just FYI. I just did the upgrades you are describing 1. I bought a aluminum baffled tank from performanceonline.com Great tank reasonable price. Doesn't hang way down like the blazer tank does. 2. Got rear disc conversion from little shop manufacturing. Very reasonable price and works great.
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
06-04-2018, 04:32 PM | #9 |
Active Member
Re: My New Ride
Very nice.
Previous C10's 69 SB CST - sold 72 Cheyenne Super LB - sold |
06-04-2018, 09:09 PM | #10 |
Re: My New Ride
looks nice... just need some more pics of it!
1969 C10, ZZ502, T400, A/C, WoodBed, Bucket Seats 1965 C10, 5.3LS, 4L60, Vintage Air, Woodbed |
06-05-2018, 09:35 AM | #11 |
Re: My New Ride
Thanks all, more pics coming soon....Rocky thanks for the info on tank and brakes, really good prices.
06-05-2018, 09:39 AM | #12 | |
Re: My New Ride
06-05-2018, 02:14 PM | #13 |
Re: My New Ride
I decided on the Boyds tank. It went in fairly easy, the hard part was the in tank pump, return line, and cutting the hole on the bed. It turned out really nice though and was worth the effort.
06-05-2018, 02:55 PM | #14 |
Re: My New Ride
Did you pull the bed off or leave it on? I would like to do it with the bed on, but unsure at this point?
06-05-2018, 03:22 PM | #15 |
Re: My New Ride
I have a wood bed and installed mine with the bed on.
Little tricky but can be done. Precise measuring for filler neck location. Enough room to tighten filler neck rubber between bed and tank. The tank from performance online came with a Metal strap with nuts welded to it. I drilled 1/2" in frame for the mounting bolts then taped the Metal strap with nuts on inside part of frame since you can't access it with tank in place. Make sense? Kinda confusing to explain. I was going to just drill and tap the frame for the mounting bolts but didn't think the frame material was thick enough to be safe. Hope this helps.
06-05-2018, 03:57 PM | #16 |
Re: My New Ride
My blazer tank required removing the bed. I also have a steel floor.
Previous owner had started the swap so the bed was already just sitting frame/tank when I got it. |
06-06-2018, 10:53 PM | #17 |
Re: My New Ride
I started the project without pulling the bed. Ended up pulling for ease of completing the project. I don’t have access to a lift and was sick of rolling around on my back. Taking the bed off was a lot easier than I thought it would be. Unhook the tail lights harness and six bolts, then have some meatheads over to help lift it off. Mine is a short bed with steel floor. Two of us could do it, four was a cake walk.
06-07-2018, 12:16 AM | #18 |
Re: My New Ride
Congrats!! Good looking truck.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
