Old 06-05-2018, 10:29 AM   #1
70GMCer
70GMCer's Avatar
Horn contact order
Can someone show me the right order in which these parts are installed onto the steering wheel?
Especially the tapered 3 hole plate thing...
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 06-05-2018, 02:11 PM   #2
Jay2Cor517
Jay2Cor517's Avatar
Re: Horn contact order
Here is a pic that I took when I was about to replace the steering wheel on my '86. It's been awhile since I did it but it may be safe to "assume" (LOL) that the first piece from the left in your picture is on the bottom
Everything that can be counted does not necessarily counts; everything that counts cannot necessarily be counted--Albert Einstein
Jay2Cor517 is offline   Reply With Quote
Old 06-10-2018, 10:58 AM   #3
Pontiac1976
Pontiac1976's Avatar
LEFT to right spring contact is up side down, then the horn holder, plastic spacer( DO NOT OVER TIGHTEN ) blue lock tight can be used half drop screws . then horn cover
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 06-10-2018, 11:03 AM   #4
70GMCer
70GMCer's Avatar
Thank you.....works.....
1997 GMC Sierra Ext
1965 Mustang
