Old 11-12-2003, 04:07 PM   #1
SEVEND2
SEVEND2's Avatar
Question Question on Alt. I Need HELP
Where does the Ground Wire go? I have a terminal on the back of the alt. for Ground and dont have a Gound wire to hook up.
Does anyone have a Ground if so where does it go.
Mine has 3 wires, 2 to the clip plug in and 1 that goes to a thread connector
also
How hot does a Alt get?? I can barely touch mine bare handed after running 5 min
Also
When I idel it is a hair above center on needle on the meter, when i rev or give it gas, it goes up , and when i get on it It goes to Full charge on the gauge.
Any input on that?
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction).
Progress on truck so far (follow link):
http://67-72chevytrucks.com/vboard/s...ad.php?t=51051
and stage 2
http://67-72chevytrucks.com/vboard/s...ad.php?t=58132
~ "Why couldn't you have just put the bunny back in the box?" ~
SEVEND2 is offline   Reply With Quote
Old 11-12-2003, 04:25 PM   #2
Slammed67
Progress = 0%
Slammed67's Avatar
Ground wire???? Is this an internally regulated alternator? If so, it shouldn't have a ground wire. There should be a wire going from the post on (back terminal) to the battery. Then a wire going from the post to the large wire on the connector. The smaller wire goes to a switched 12v source. This is how mine is wired up anyway.
I don't recall how the externally regulated ones are wired up
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 11-12-2003, 04:49 PM   #3
SEVEND2
SEVEND2's Avatar
It says GND, on the Alt. Back side. I dont have a Wire for it, I was just wondering it I should have.
and stage 2
Old 11-12-2003, 05:45 PM   #4
pbmcauliffe
pbmcauliffe's Avatar
Most of the time the ground is carried via the mounting of the alternator to the engine, but some times they don't ground well (powder coated cases, chrome, etc.) so you can run a cable from the gnd terminal to the engine block, frame, etc. to better the grounding.
pbmcauliffe is offline   Reply With Quote
Old 11-12-2003, 06:17 PM   #5
zyggy72
Can't kick the addiction!
What year truck? If it is your 72 and is the original setup then, you also have a voltage regulator and if I remember correctly, the ground wire goes from the back of the alt. to the voltage regulator or something of that nature.
If only I had the factory assembly manual in front of me, I could tell you for sure.
zyggy72 is offline   Reply With Quote
Old 11-12-2003, 06:54 PM   #6
SEVEND2
SEVEND2's Avatar
Got it for the ground Question
Ok, should the Alt. be getting hot (almost to hot to touch) after 5 min- 10 min?
and anyone else having Volt meter changes when the RPM's go up?
and stage 2
Old 11-13-2003, 01:04 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Your volts may go up a little when you rev it...or more acurately drop at idle...but if it goes much past 14 volts, you have a problem.
Old 11-13-2003, 01:14 AM   #8
SEVEND2
SEVEND2's Avatar
well at idle I am about center on the meter, any increase of RPM increases the needle to more charging, When i am driving its is pegged past Full max charging.
Might have to take it out and go exchange it again
and stage 2
Old 11-13-2003, 01:39 AM   #9
Longhorn Man
You talking volt meter...or the stock amp guage?
If you are going by a stock guage, put a hand helpd multimeter on there and see what's actually going on.
Old 11-13-2003, 02:32 AM   #10
SEVEND2
SEVEND2's Avatar
yeah I am just going off the In dash Meter.....
The Wires nor the Batt. is warm or Hot, just the casing of the Alt is Very warm, enough to pull your had away at first touch (i never really noticed that before).. But, thanks for the idea on the Multi Volt meter on the connectors......
What points should i test? Across Batt terminals, other points??
and stage 2
Old 11-14-2003, 12:50 AM   #11
Longhorn Man
Battery is fine. Make sure to rev it up when you test the voltage too.
I've never heard of a set up (working properly) that will move the needle that much when you rev it up.
Old 11-14-2003, 06:51 PM   #12
SEVEND2
SEVEND2's Avatar
Talking
OK, found this..........
Alt. Was good, not causing the problem...
It was the External Volt reg. I guess and the guess of a few local Auto shops that the Other Alt. Went out it shorted out or damaged the Volt Regulator.
So.
I replaced the regulator with a new one
And BAM.. It works Great again, max charge was 13.6V
Running at various rmp's at 12.4 average
Just an FYI. If anyone else has this problem, Check the Regulator!!
And thanks Members for your help
and stage 2
