Heavy Duty 3800 5K bags need cupped. How deep do they need to be? Car hauler C30
I have a 1970 C30 with 1975 C30 front suspension. The truck is a car hauler. 31 tires. I'm not planning on slamming it but like to be able to lower it when I need clear the dovetail in low spots and to raise it to help with loading and I would like to be able to air it up when I have a heavy load on it to keep it for riding on the bump stops.
I ordered the bags from Chassis Tech. They are the 3800 bags rated at 5,000 LBS Each. The compressed height is 4.5 Inches, Normal Height is 9 Inches and max extended is 12.5 Inches with a diameter of 9 inches compressed. I have already cut one of the control arms to be cupped. I don't know how deep I should cup it? From most the the threads I have read it looks like most people do a 2 or 2.5 inch cup as most bags are 2.5 compressed. However my bags are 4.5 inches compressed. So should I cup mine 3.5-4 inches? Pics of the bags. ![]() ![]() I don't have fittings yet I just have a valve stem wedged in there leaking air max is 12.5 but its not to it in the pic, but you get the idea. ![]() unmodified control arm. ![]() ![]() ![]() compressed this would be about a 2 inch cup ![]() ![]() ![]() Should the cup be angled like factory? ![]() or should it be a even all the way around? ![]() ![]() heavy load ![]() stock height maybe a bit of sagg. ![]() |
Re: Heavy Duty 3800 5K bags need cupped. How deep do they need to be? Car hauler C30
Well I went ahead and started on cupping my lower control arm. I went with a three inch cup as the bags only compress to about 4 inches and most bags used on c10 compress to about 2.5 inches and it looks like most of them use a 2 cup. I'm not planning on slamming it or any thing. I'm just trying to get the bag to operate efficiently. I assume when the bag is at rest or slightly compressed is where the bag is most effective? granted I know very little about air ride. I have measured my current ride height on the truck from the top of the lowering control arm to the bottom of the spring mount to be 6 inches. The bags at rest are 9 inches and with the 3 inch cups it will be at the stock ride height of 6 inches. The bags max height is 12.5 inches so I can lift the truck 3.5 inches and lower it about 5 inches.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() The mounting points are wider than normal bags that and the mounting points needed to be moved over so I milled some new slots and moved the hole over. ![]() ![]() ![]() This is it at 6 inches. ![]() |
I'm a bit late to the post but I wouldn't have the cup sit any lower than the arm. It is already the lowest hanging part on the front end and having it sit an inch or two lower seems a bit worrisome.
Chassis Tech is also known to put out some less than quality products. I assume the bags are DOT approved but I would spend some extra time really looking them over to make sure they don't have any defects.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
what tinydb84 said less then quality products. my buy bought a set of bags and I filled them and stuck in 5g bucket with water and they all leaked at the seam. so we bought bags from switch suspension (their economy line) and they was great to work with and bags didn't leak. they also have larger bags.
