Help on correct rim offset
I am planning to put on a set of 17x8 rims and I am concerned about the the offset. The rims I am looking at are 4 1/2" offset. I will have drums in the rear. Also what does "Hub Centric" mean.
1969 GMC S/B S/S 3" drop |
Offset or backspacing is the measurement from the backside of the mounting flange to the edge of the wheel....with that wheel you'll have 3 1/2 inches showing, should fit fine...
Thanks for the info. I just ordered a Front Disk Break kit from GMC Paul. Will get the rims now
hub centric means that the wheel is centered on the the center hub of the spindle/axle. lug centric means that the lugnuts center the wheel.
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
