06-10-2018, 12:19 PM | #1 |
Evans waterless coolant, in BBC ??
Anyone run this stuff? Local motor head suggested it in my 496 BBC, need some opinions before spending $325 Thanks in Advance
06-10-2018, 02:14 PM | #2 |
Re: Evans waterless coolant, in BBC ??
I have not used this product , but I am a Avid BMW guy and a lot of threads have taken place about Evans waterless coolant on some of the BMW forums . you might want to Google NO-Rosins Test results . and take a look at there report and findings on the subject of Evans waterless coolant study they did.
06-10-2018, 02:54 PM | #3 |
I haven't used it either, but... A quick glance online reveals the stuff is 50 bucks a gallon. My quick bad-math fills my BBC block and radiator up for less than 325 bucks though!
Am I missing something? Are the flushing agents/testing equipment absolutely required? -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
06-10-2018, 04:34 PM | #4 |
I'd say that, if you're gonna do it, then the flushing and etc is required. Personally, I think I'd probably only use this stuff if I had a brand new motor and radiator, etc. Otherwise, anti-freeze has worked just fine for, oh, a century. I have to admit, I am interested in this stuff, sounds pretty good, but there is a price. And this is a crazy price.
06-10-2018, 06:26 PM | #5 |
I was curious to see what is in this product so I googled the Material Safety Data Sheet. This product is 80-85% ethylene glycol. http://www.hrpworld.com/store/media/...%20-%20SDS.pdf
06-10-2018, 08:25 PM | #6 |
FWIW, ethylene glycol is standard green antifreeze.
06-10-2018, 09:45 PM | #7 |
Ive thought about running it in mine but haven't decided yet. My entire setup is new so I have the benefit of not having to flush.
06-10-2018, 10:54 PM | #8 |
My first thought is why? Too much money in the bank and need to waste some?
Why not use antifreeze and no water? I seem to recall it'll run a bit warmer, but WTH, at $10 a gallon not much downside to trying. Or run 50/50 and change it every few years as recommended. |
06-10-2018, 10:58 PM | #9 |
I think the most important tip when it comes to coolant, if you mix your own, is to use distilled water. That's an old wives' tale I actually believe. I don't believe many folks used to do that (I didn't). But then again, we didn't buy every sip of water we drank in a plastic bottle back then either, ha. By today's standards, the water I drank from the tap and the garden hose as a kid, just a few miles from the steel mill, shoulda killed me decades ago I'm a medical miracle.
06-11-2018, 07:24 AM | #10 |
Running it in my new 400SBC and haven't had any issues.
1968 C10 SWB 400SBC with VN327 20's 1972 K5 Blazer 383SBC 2011 Cadillac CTSV |
06-11-2018, 07:31 AM | #11 |
Thanks guys, Its new motor but I put water in to get running is why it be pricey, the flush is high also.
06-11-2018, 08:09 AM | #12 |
Why bother ? If you have a leak or hose failure you can only use more ,You can't add water ever and if you do they suggest you drain and repeat fill process . WHY waste your $ ?
The effect of Evans waterless coolant on cooling system temperatures will depend on the engine and cooling system configuration, as well as driving conditions. Vehicles running under normal operating conditions should show either no change or a slight increase in temperature. In high horsepower applications, the temperature effect of running Evans waterless coolant will depend on the engine and cooling system components. ( With Evans waterless coolant, operating temperatures may be modestly higher than those of water-based coolant ), depending on driving conditions and whether the vehicle is stock or configured as high-performance. When the engine is stressed, the coolant absorbs more heat and temperatures rise. This is not a concern when using Evans waterless coolant. The combination of the high boiling point of Evans waterless coolant and a correctly-sized cooling system means that an increase in temperature can be accommodated without cooling system failure. |
06-11-2018, 08:56 AM | #13 | |
Who Changed This?
06-11-2018, 08:59 AM | #14 | |
06-11-2018, 09:15 AM | #15 |
Thanks everyone, I am sticking with antifreeze 50/50
06-11-2018, 12:41 PM | #16 |
I use distilled water and BMW coolant 50/50 in my DD BMW as that is what is called for in the manual. Was not aware of the science quoted in this thread regarding distilled water however!
My BMW cooling system is actually easy to bleed. It's got an electric pump that lives at the very bottom point of the system ( lowest point ). The thermostat lives down there right next to the water pump. Once it's all topped up, the pump has a mode that it will go into in order to pulse out all the air. Takes about 12 minutes for the pump to complete the bleeding function. This starts the pump on the bleed procedure: ( place key fob in dash, push start button to wake up car but not start, put heat temp to MAX, fan on low, push gas pedal to floor for 10 seconds ) -klb
06-11-2018, 02:17 PM | #17 |
We used to use distilled water to add to the BATTERY in the days before maintenance free batteries came along .
06-11-2018, 03:01 PM | #18 | |
06-11-2018, 04:35 PM | #19 | |
Who Changed This?
06-12-2018, 03:29 AM | #20 |
I think its alcohol based.
06-12-2018, 03:59 AM | #21 |
70/30 antifreeze is impossible to beat
I BELIEVE IN JOHN 3:16 |
06-12-2018, 10:31 AM | #22 | |
let me say fisrt I have a backround in water treatment.,what I am trying to convay in my statement about distilled water is that water is a great conductivity for all things , thats why its such a good canidate for heat transfer and used in cooling systems , but it also conducts minerals ,by it own nature as it travels through the ground it conducts the minerals in that specific region the water flows through ,if you live in a region that contains a lot of sulfer the waters sulfer will have a higher PPM (parts per Millon) count then another region of land mass , When you start out with distilled processed water you have a blank canvis for the water as it travels through it will have a great conductivity level for the enviorment in witch it is placed.we are not talking drinking water here but you want to try to have a water that is tailord to live within in a system it was desighned for , so depending where you live depends on how well the water will adapt for your cooling system. |
06-12-2018, 10:53 AM | #23 |
Who Changed This?
OK, I dug around a little on my own and did learn that distilled water can be bad for the cooling system because it will leach material from the cooling system until it comes to equilibrium. But using antifreeze with a reserve alkalinity helps, as does using a water pump lubricant. Water pump lubricant is a water soluble oil. It coats the interior of the cooling system with a thin film which does not inhibit heat transfer but stops the leaching of metal by the distilled water.
