Old 06-10-2018, 06:09 PM   #1
Rockit
Rockit's Avatar
Modern take off wheels
I have a 1972 4x4 k 5 and my question is will modern 17” rims fit my blazer ? I see two things to look at bolt pattern and hole diameter.
Rockit is offline   Reply With Quote
Old 06-10-2018, 06:35 PM   #2
franken
Re: Modern take off wheels
Also look at offset, which I suspect will make the swap impractical.
franken is offline   Reply With Quote
Old 06-11-2018, 09:33 AM   #3
raggedjim
raggedjim's Avatar
My blazer has modern wheels, I had to machine the center bore to size as the centerbore on modern wheels are smaller.
Good luck, Rg
raggedjim is offline   Reply With Quote
Old 06-12-2018, 01:20 PM   #4
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
as mentioned center bore will be the biggest hang up with them fitting... but you might need spacers too...
Current Rides:
Vintage Evil - 72 Chevy C10 (Always a work in progress) Vintage Evil Build Thread
EvilK5 - 71 K5 Blazer
Evil Twin - 2006 Suzuki M109R
EvilDmax- 2018 GMC 2500 Denali Duramax
chevyguy_72 is offline   Reply With Quote
Old 06-12-2018, 01:44 PM   #5
Killer Bee
Killer Bee's Avatar
haven't taken any measurements or have any idea if anything was modified, but my 71 K20 burb with stock axles and hubs as far as I know, came with late model aluminum 8 lug wheels and all seems to clear fine..
good luck!
Old 06-12-2018, 04:27 PM   #6
chevyguy_72
Vintage Evil
8 lug wheels will all work fine... is the newer 6 lug wheels that have smaller bore...
good luck!
Current Rides:
Old 06-12-2018, 06:01 PM   #7
Killer Bee
Killer Bee's Avatar
^ thank you for clarifying that! the rusty blue k1500 is 6 lug and I may need this info later
Old 06-13-2018, 04:47 PM   #8
chevyguy_72
Vintage Evil
No prob...
Current Rides:
