Old 06-11-2018, 12:29 PM   #1
Awjunkies
Suspension question.
Wondering if anyone else has encountered this. 72 k10 that I believe is stock height. Front springs are completely flat but sit about 1/16 above my steering stabilizer. Whenever I go over bumps it smacks it. How do I remedy without adding a big ole lift?
Thanks in advance
Awjunkies is offline   Reply With Quote
Old 06-11-2018, 04:20 PM   #2
kwmech
Re: Suspension question.
Put a 3rd factory leaf in it, it will raise it about 1-2''
Old 06-13-2018, 02:39 PM   #3
CrewCab59
CrewCab59's Avatar
You also need to check the spring eye bushings and shackle frame bushings. If your spring pack has only 2 leafs you can add the option 3 leaf. The stock spring are flat to neg arch but if there broken down than you can buy new stock spring or a 2" lift springs.
Measure from the bump stop to the top of the leaf spring top plate.
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
