Vortec 350 ac retro fit
Has anyone swapped in the 96-01 serp brackets and made the AC work?
79 Corvette- 406/7004r Holley EFI 87 V10- 5.7L, Vortec heads, E110026, 410s 35s, 700r4 |
Plays with trucks
Re: Vortec 350 ac retro fit
I bought a universal hose kit (fittings and hoses) with the compressor fitting from Vintage Air, made up the lines, and had them crimped at a local hydraulic hose shop. You need to 'clock' the hose to the fittings with masking tape and marker if they aren't straight fittings. Also a good time to change your drier and orifice tube.
Gary My Dad's Old Truck 1985 ![]() |
I went to the pull-a-part and got the top section of the hoses from a balzer. Then I had a local radiator shop weld on some crimp fittings so I could run them down and under the radiator.
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ Last edited by bluex; 06-17-2018 at 01:31 PM. |
#5 | |
I use the AD244 140A from a 2000-2005 suburban/tahoe. It bolts right in and uses the same plug as a CS130D that was normally on these setups
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
