06-11-2018, 05:24 PM | #1 |
Can Motor/transmission be removed together?
I'll be removing a SBC with a Turbo 400 and installing a SBC with a 700R4. While only removing the hood and radiator for clearance, can the motor and transmission be pulled from the top while still bolted together? Or will I need to unbolt the transmission and remove it from the bottom and motor from the top separately? This is on a 66 C10.
TIA |
06-11-2018, 07:29 PM | #2 |
Re: Can Motor/transmission be removed together?
Yes you can pull them together. You may need to pull the trans crossmember to let the trans drop down to get enough angle.
06-11-2018, 07:43 PM | #3 |
1965 Chevy C10, 2005 4.8L/4l60
Yep
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
06-11-2018, 10:45 PM | #4 |
Thanks! Appreciate it.
