Old 06-11-2018, 05:37 PM   #1
kenr74
How low is too low?
In process of dropping my C20 and need some advice.
Did the flip in the back and removed 3 of 10 leafs. Looks good to me.
Did 3" spindles in front and it only dropped 2.25". Now the front sits about 1.5" higher than the rear. (measurements were inside my shop on cement floor)
Looking at the front though if I cut the coils to level it out I will just barely have the tire higher than the lip of the fender. Is that going to cause issues? I have some pretty big tires on it now and don't see changing them anytime soon.
I'm trying to decide between cutting the coils or adding a leaf back in to level it out.
kenr74 is offline   Reply With Quote
Old 06-11-2018, 06:15 PM   #2
Re: How low is too low?
I'd put a leaf back in.
Old 06-11-2018, 10:43 PM   #3
Mike C
Mike C's Avatar
Me too.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-11-2018, 11:52 PM   #4
rjs53
If your planning on keeping the tires you got, you can put a leaf back in or get a different offset front wheel, move the wheel in and cut the front spring.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 06-12-2018, 08:33 AM   #5
hewittca
hewittca's Avatar
That's a lot of tire up front. It would look cool with the front dropped a bit more, but I have to agree with everyone else; if you're going to leave those tires for now then add a leaf back in to the rear.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10 | Oscar the 70 C10
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 06-12-2018, 09:06 AM   #6
I'll put it this way, it won't look "too high" if you bring the rear up to level with front. Also, for function, you still have stock spring rate in front with less in rear now. Adding a leaf will be more balanced.
Old 06-12-2018, 09:20 AM   #7
KevinK7
KevinK7's Avatar
Add another to the "I agree" with putting a leaf back in. It's still gonna look lowered : )
KevinK7 is offline   Reply With Quote
Old 06-12-2018, 10:21 AM   #8
kenr74
I raised the rear so it sits level and it does look good. Wish it was lower but those tires are brand new so they will be around for a while.
The way the wheels sit I can't see going any lower in the front with the tire/wheel combo I have. Might drive it for a while and see if it rubs now before doing anything.
Old 06-12-2018, 11:57 AM   #9
kenr74
Pic of it sitting level(back end jacked up). Looks ok. Tires are 235-85-16 by the way.
