Old 06-12-2018, 09:14 AM   #1
jcramsey
jcramsey's Avatar
Bagged 62 C20...what track bar
In the process of bagging my 62 C20 and wondering if anyone out there has a track bar for this. Called CPP and tech guy said they they had one but it would have to be modified to work. Anybody know of anything out there?
Thanks!
The Egg Hauler
The Government Mule
jcramsey is offline   Reply With Quote
Old 06-12-2018, 02:10 PM   #2
LVPhotos
LVPhotos's Avatar
Re: Bagged 62 C20...what track bar
Porterbuilt, or build your own. I had to modify CPP after 3rd one showed up wrong length.
http://rodendsupply.com
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 06-12-2018, 09:04 PM   #3
jcramsey
jcramsey's Avatar
Thanks LV....Might have to give PB a call.
The Egg Hauler
The Government Mule
Old 06-13-2018, 04:35 PM   #4
jcramsey
jcramsey's Avatar
Called PB and they said they didn't have anything that fit a 62 specifically. It looks like their 63-72 kit bolts on to the frame so it might be usable? Is that what you were thinking LV?
The Egg Hauler
The Government Mule
Old 06-13-2018, 06:42 PM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
The 60-62 frames are wider. Idk if the 63-72 will fit.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 06-13-2018, 10:07 PM   #6
LVPhotos
LVPhotos's Avatar
Yes the 62 is wider... but this is the 60-62 bar PB Sold me. This is welded to outside frame, cut and re welded.Attached to PB arms. But the rod ends and bar is what you can use. Nate usually can get the right part. But get the ends at Rod ends and have it welded up local. Give yourself 1/2" to 3/4"each side if rod end is 1", for max 2" adjustment with min 1/2" inside rod.
You can get a big bar, ask the rod guys.
Old 06-13-2018, 10:23 PM   #7
LVPhotos
LVPhotos's Avatar
Ps the 62 bar was stock mount on axle and longer than the 63 up.
