Old 06-12-2018, 11:14 PM   #1
tdishon
Another seat thread
I have a 59 and I am putting in an Astro van 2nd or third row seat.
Looks like this:
The width is 55" and it sits great and feels great, but does set me about 2" to the left of the steering wheel. Is this common?
I removed the head rests and it looks great and only sticks above the big rear window about 2"
I think the only way around it looking a little off is to get a flat bench seat.
I might do the bench seat if I new what year/make/model would bolt in and be a good fit.
Any help or pics would be great.
tdishon is offline   Reply With Quote
Old 06-12-2018, 11:25 PM   #2
Dan in Pasadena
Dan in Pasadena's Avatar
Re: Another seat thread
It’s “off” even though you centered it in the cab? Odd.
A lot of guys use the 88-98 Silverado seat. Some cut down the base’s height. Personally I prefer sitting a little high.
BUT, you can also just use the stock bench. I did. I removed the stock springs and replaced with all foam like a modern bench. This way it can be contoured to look any way you want. I’m posting from my phone but I’ll try to include a pic of it.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 06-12-2018, 11:30 PM   #3
my56chevytruck
my56chevytruck's Avatar
If you're comfortable with the offset then what makes you happy is all that matters. You said 2" to the left of the steering wheel, or do you mean to the right?? Any chance of moving the seat slightly one way or the other before mounting to the floor?? I have a 56 and I got a bench out of a 89 chevy pickup and it fits great. I'm real happy with the choice, but having buckets are cool as well.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 06-13-2018, 12:20 AM   #4
tdishon
I centered the seat in the cab. If you stand in front of the truck looking in or stand behind it, you can tell the steering wheel sits towards the passenger side about 2" from the center of the headrest. I guess it's not a big deal. It feels great tho... I tried moving the seat over about an inch, but it made the passenger side look really off. I suspect many people with a split bench might be having the same issue or I'm just making it an issue in my head...
I'll look into the 88-98 silverado bench seats. I heard they are a little wide, but will fit. I would love to see some bench seats!
Old 06-13-2018, 12:40 AM   #5
Dan in Pasadena
They’re slightly wide but not enough to keep dozens of guys from using them. But lots of guys seem to have an issue with their height and cut them down. You can tell by the factory openings on the seat base being smaller than the close-to-square shape they are stock.
Old 06-13-2018, 03:46 AM   #6
MiraclePieCo
MiraclePieCo's Avatar
Everyone I know says that when they drive their truck they don't notice the slight misalignment.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 06-15-2018, 01:57 PM   #7
1project2many
GM vans made from 73 to 95 are like this. A centerline through the steering column and wheel does not align with the center of the seat. Most folks never notice.
1project2many is offline   Reply With Quote
Old 06-22-2018, 04:52 AM   #8
QBRacing
@tdishon
those are the seats I am trying to find. can you confirm if they are from the 96- astro or the 91-95 astro.
I have a feeling I've been emailing wreckers in LA for the wrong year range which is why I've had no luck yet.
QBRacing is offline   Reply With Quote
Old 06-22-2018, 10:08 AM   #9
tdishon
These are out of a 2000 Astro. Make sure the van has the LT option.
Old 06-22-2018, 10:50 AM   #10
mikebte
I have a bench out of a 93 GMC 2500 in my 59. I'll get you a photo tonight. The legs fit right on the floor and mount very flush.
mikebte is offline   Reply With Quote
Old 06-22-2018, 10:59 AM   #11
tdishon
Love to see the pic of the 93 GMC seat!
Old 06-22-2018, 11:30 PM   #12
Softpatch
Softpatch's Avatar
here those picture I have of my 02 3rd astro seat into my 59 Viking
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 06-22-2018, 11:58 PM   #13
tdishon
These are comfy seats. How does your seat line up with the steering wheel? I think once you sit in it and the wheel is a little off, it doesn't really matter.
Old 06-23-2018, 02:30 AM   #14
QBRacing
Do you just use the apache lower seat mount or do u need to fabricate something up for the astro seat
Old 06-23-2018, 01:12 PM   #15
abig84
abig84's Avatar
Speaking of Silverado seats, what's the usual way to mount them? Use the 50s brackets or weld or bolt on the Silverado seats using what's already attached to the seat
abig84 is offline   Reply With Quote
