Old 06-13-2018, 10:37 AM   #1
bbluma
Door check retainer
Hey y'all, my door check retainer is broke. More specifically the part on the cab, so the part on door has nothing to attach to and pin to go in. What's the best fix to this? Is there a way to avoid cutting and welding something in? Thanks.
bbluma is offline   Reply With Quote
Old 06-13-2018, 11:49 PM   #2
AJCK87
Re: Door check retainer
The retainer bolts in as far as I know. Least it does on my 63
AJCK87 is offline   Reply With Quote
Old 06-15-2018, 08:17 PM   #3
Rusty63
Rusty63's Avatar
theres a mod. listed somewhere on here to replace with jeep Cherokee parts,i just picked a set up at wreckers,havent had time to install yet though...
http://67-72chevytrucks.com/vboard/s...d.php?t=446066
Rusty63 is offline   Reply With Quote
Old 06-16-2018, 09:06 AM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
This is a door check info: http://www.persh.org/pickup/DoorChecks.htm
Notice the cab side.
And a good forum thread bout halfway down is replacement info - http://67-72chevytrucks.com/vboard/s...d.php?t=668783
This is a funny thread on YOUR issue: http://67-72chevytrucks.com/vboard/s...d.php?t=714937
Old 06-16-2018, 01:38 PM   #5
61K10
61K10's Avatar
Here you go people--e-bay search jeep door ck bracket. These are new. If getting yours from a u-pullet place just get the bracket also. Bolt on or weld on.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 06-16-2018, 03:46 PM   #6
The Rocknrod
Moderator
Nice new parts
Still wondering, do those require a self tapping bolt? Or do you have to get into the A-pillar to used a backing bolt?
Old 06-16-2018, 04:09 PM   #7
61K10
61K10's Avatar
my 61 probably has a plate thats tack welded and threaded. later non bolt on could use some kind of nut-cert. or weld on.
1961 chevy K10
Old 06-17-2018, 10:54 PM   #8
padresag
i do have a couple off a 62
ron
padresag is offline   Reply With Quote
Old 06-27-2018, 01:25 AM   #9
luvbowties
luvbowties's Avatar
Smile Re: Door check retainer
Hey bbluma, check & see if there are threads in/behind those 2 holes. If so, just get the proper Jeep retainers and bolt right in : get the retainers & do not forget to get the bolts too.
My Jeep retainers did not allow my doors to open quite far enough; so I removed the rubber bumpers to where I could slice off half. I could've cut a bit more, but I just let well enough alone, after checking, at that point.
Good luck with your project(s)!
Sam
luvbowties is offline   Reply With Quote
Old 06-27-2018, 01:33 PM   #10
61K10
61K10's Avatar
Just a note--the jeep bolts are metric
1961 chevy K10
