help with chrome and alum.cleaner
what are some things you all use for cleaning and shinning chrome and alum. grilles,wheels, ex. maybe some hints on small polishing tools thanks bill
Pronounced "Pew-al-up"
When I was in the Navy they used to make a Powdered drink that they kept in a cooler on the messdeck, we called it "BugJuice". That stuff could clean Chrome, Brass, Aluminum you name it!! And it didnt taste too bad either!!
![]() Actually i was interested in the same thing for my grill, but just decided to get a new one. I was looking into this stuff though.... Not sure how good it is. ![]() http://www.topoftheline.com/dulalchrom.html
Classic GM Trucks of Washington Club Member 1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's, Power Locks, Truck Photos |
We use Turtle wax chrome cleaner for hand polishing aluminum and chrome. If it is bad, we use 00 steel wool with the polish.
For stainless, depending on condition, we wet sand with 240, 400, 600 grit and then buff on a buffing wheel using Eastwoods stick for chrome. It takes a lot of time and requires some practice but the results are usually very good. Jim |
72 LONGHORN OWNER
"Mothers" Mag and Aluminum Polish.works wonders and alot of elbow grease...........
72-SUPER CHEYENNE/20 LONGHORN 70-C/30 DUALLY |
I use the Mother's product. Works well.
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
![]() Join Date: Mar 2000
Ya may not believe this but a bottle of coke with a ball of aluminum foil to scrub with will clean and polish chrome better than anything else ( beats naval jelly, chrome polishes etc.... )when it comes to aluminum though I also prefer Mother aluminum polish.
GMCPaul |
![]() Join Date: Feb 2001
I have used a lot of brands of polish/cleaner for polished aluminum wheels and there is nothing better than California Customs......... My wheels are 8 years old and they look better than most new polished wheels.
Try spinnin 4 rear tars
I use Mothers Chrome Polish and one of those little green & yellow scrubby sponges. I use the rough side if I need to scrub a lot of gunk off, but just the softer side and buff. Then wipe away with a pair of old shorts
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
#9 | |
Formerly yellow72custom
For removing surface rust on chrome, i have personally have good luck with SOS pads.....removes the rust and cleanes up the wheel with the soap.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
ready for reassembly
Is there any way to get out the little scratches on grills, t.light bezels etc. MY grill polishes up pretty well, but I still have the scratches
stock 71 4x4 2003 Jeep Liberty, rocky mountain edition I'm obsessed, and wouldn't have it any other way! |
Thats the Hillbilly way
Im with Mudder67 I use California Customs ,best and easiest I found ..
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
thanks for the info. ill try some of those things and see how they work that coke and foil sounds interesting
i have 67/72 chevy truck parts f/s. |
