Old 06-16-2018, 04:42 PM   #1
slotard
Front bumper mounts/braces
I have a '73 C20
A month and change ago someone ran a red light and I t boned him, he denies that he ran the light, so I'm fixing the damage myself.
The front bumper bent pretty well. Someone was kind enough to give me one that's in decent shape, OEM. Not perfect, but plenty good for the overall condition of my truck.
I pulled my bumper and found that one of the inner mounts was cracked on both sides, the other on one side. There's enough rust that it doesn't have anything to do with the crash.
One of the outer braces was bent pretty well, I went to straighten it and it cracked too. The other outer brace isn't too bad, but it isn't in great shape either.
A couple questions:
Is the C20 bumper bracketry the same as the C10? I suspect so, but figure I should ask anyway.
Where should I get replacement brackets/braces? I see LMC has a kit with all of them for $80. Junkyard is an option but given that mine weren't in great shape to begin with I suspect the same will be true there.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 06-16-2018, 04:58 PM   #2
Re: Front bumper mounts/braces
C20/C10 same brackets depending on the year. I am guessing the 80 & older should work. I use LMC as a guide. If the part# is the same, then they are the same.
Being from Cali, you could probably find decent one in a yard. Not like the northeast with all the salt.
Old 06-16-2018, 05:37 PM   #3
slotard
Is cracking uncommon for the inner brackets? The reason I was thinking new is that both of mine are cracked and it doesn't look like crash damage.
1973 C20, 350/350
Old 06-16-2018, 06:41 PM   #4
Have not ever had any crack on me unless they were hit, or rusted to heck
Old 06-17-2018, 11:44 AM   #5
slotard
Hmm, I wonder why mine were broken. I suppose it's possible that it's been crashed before.
1973 C20, 350/350
Old 06-25-2018, 07:35 PM   #6
Pontiac1976
Pontiac1976's Avatar
You could be right about it being crashed before or some one was try to pull some thing stuck & heavy chains on the brackets I see that be a problem some times.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
