Front Spindle Question (66 C10)
I have a set of 82-92 Camaro Wilwood aluminum hubs, 12" rotors and Wilwood calipers that I purchased for $1k new. I sold my camaro and want to know if they will fit my 1966 C10 if I swap spindles to the camaro spindles and use these brakes?
Any info is appreciated. |
#2 | |
Re: Front Spindle Question (66 C10)
#3 | |
Posted via Mobile Device |
It may be "doable", but there's no advantage. Everything on the Camaro platform is designed for the weight and chassis dynamics of that particular car. The truck stuff is heavy duty for a reason. C10 trucks utilize narrower frame rails with longer control arms, so the ball joints and spindles actually take alot more load than "car" spindles. Therefore, the spindle/hub assembly won't handle the stress the truck chassis will put on it, which means you'll be spending more money down the road constantly replacing spindles and hubs and possibly fixing sheetmetal that the loose wheel tore up.
