Old 06-17-2018, 09:25 PM   #1
Ltruck268
Exclamation Rear axle shaft 63/64?
New to the forum
I have a 68 k10 fully restored.
Upon dissecting the rear end to replace an axle shaft I found that I have 17 spline axle shafts and am looking for a replacement.
Any help is appreciated
Ltruck268 is offline   Reply With Quote
Old 06-18-2018, 01:23 PM   #2
61K10
61K10's Avatar
Re: Rear axle shaft 63/64?
12bolt or eaton? 68 should have 30sp axles as you know. try Dutchman axles, they might make one for you in 17sp. post up a pic of axle.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 06-18-2018, 02:41 PM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
I have 17 spline axles from a 64 diff I dismantled.
Old 06-18-2018, 03:54 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
You might look up Aspen Auto Parts in Arizona also.
Old 06-18-2018, 10:59 PM   #5
Ltruck268
I'll post pics as soon as possible. It is a 12 bolt rear end. I assume it was originally off a 63/64 truck. I appreciate the responses, it looks like Dutchman axles makes what I need
