Old 06-17-2018, 10:28 PM   #1
Bigd18
Ignition Switch indexing off
Replacing the ignition switch and cylinder lock on my 64. I bought both from Napa (Echlin) and everything works fine. The key, however, is not in straight up/down position as the original due to the indexing of the switch in the dash. Has anyone else ran into this issue? Does the Counterpart switch have the proper indexing?
Bigd18 is offline   Reply With Quote
Old 06-27-2018, 01:36 AM   #2
luvbowties
luvbowties's Avatar
Smile Re: Ignition Switch indexing off
Tell us what function is not straight up and down, Acc,, Lock, Off, On, or Start?. Sounds like you do not have the switch/bezel aligned properly. I'd check that before I began grinding...
HTH, Sam
luvbowties is offline   Reply With Quote
Old 06-27-2018, 10:41 PM   #3
Bigd18
I was thrown off because my original switch did not have ACC position. It works fine.
