06-18-2018, 11:13 PM | #1 |
SWB 6-lug axle vs LWB 5-lug axle
Hello,
Currently building a 71 C10 LWB 5-lug with leafs and have a chance to purchase a SWB 6-lug coil spring frame with running gear. My question is will I be able to swap my current 5-lug axle/spindles into the SWB and retain the coil spring/trailing arm setup? I will be picking this up early next week. Thanks in advance! |
06-18-2018, 11:20 PM | #2 |
Re: SWB 6-lug axle vs LWB 5-lug axle
no, the 71 axles are wider. it's easier to swap front complete cross members if the 5 lug is in better shape .Disc ?
06-18-2018, 11:30 PM | #3 |
06-19-2018, 12:43 PM | #4 | ||
"I ain't nobody, dork."
What GOM said. I have a 1969 housing in my 1972 GMC, but I had to get 5 lug conversion axles made by Moser to slide into the narrower 1969 housing.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
06-19-2018, 01:07 PM | #5 | |
Another option I was thinking about was to weld on trailing arm pads on the 5-lug leaf axle assembly from the 71. Found these on a quick google search. |
06-19-2018, 02:07 PM | #6 | ||
I ordered them from Summit Racing and got free shipping. $260 bucks shipped to my door. Here is the link:
https://www.summitracing.com/parts/m...gmt5/overview/ Gary
06-19-2018, 07:32 PM | #7 | |
06-19-2018, 09:22 PM | #8 |
Too many projects
The axles may be the same width if the axle is a late 1970. In 70, there were 2 widths of axles:
Early: 62 3/8” WMS, same as 67-69 Late: 63 3/4” WMS, same as 71-up It would help to put a tape measure on the axle in the SWB before ordering parts, as there is a small chance that your 5 lug axles will fit if it’s the late 1970 axle.
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
06-19-2018, 10:36 PM | #9 |
First thing we need to know is what year is the SWB chassis. If it's a '70 with a '70 rear then you can swap the 5-lug axles in straight up. '70 was the first year for the wider housing and last year for 6-lug
06-19-2018, 11:02 PM | #10 | ||
Thanks for the invaluable information. I will definitely take measurements and get the production date info as I will be picking it up on the 26th of this month. Again, thank you for all the info as I like to brainstorm my options. |
06-19-2018, 11:33 PM | #11 |
Good luck and now that I'm thinking about it, Welcome to the site!
Not sure if it's been mentioned or if you'd consider going this route, but if it's the narrower housing you can buy 5-lug axles for that length
06-20-2018, 12:02 AM | #12 | |
Gasoline71 sent a link for the Moser 5-lug conversion axles, good to know there are off the shelf conversion axles. |
06-20-2018, 05:33 PM | #13 |
Still plays with trucks
You also need to add a panhard bar mount bracket.
An Eaton HO52 / HO72 housing from a 3/4-ton has a nice design bracket that is welded to the axle tube that is easy to copy and install onto another rear end for a trailing arm conversion. This is by far the least expensive way to go if your existing brakes and axles are in good shape. If you have worn bearing surfaces on your 50-year old axles (likely) and / or your brake drums are shot then the replacement axle method may be a more cost effective option. Inspect your parts closely before you commit to one way or the other. One upside to the conversion mounting pad option is that you can set your pinion angle and U-joint angles properly to accommodate for a lowered vehicle. I didn't think this was going to be such a problem as my truck isn't lowered that much but it ended up needing over six degrees of pinion angle correction to bring the U-joints into the correct drive angle. This was after moving the front trailing arm mount point to drop the anti-squat down to 100% so it didn't hit the tires so hard but it is still something that needs to be looked at with a lowered truck.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
06-21-2018, 01:06 AM | #14 | |
Thank you for the alternate housing information. Good point on setting pinion angles if going the arm pad way. |
06-21-2018, 07:53 AM | #15 |
No need to take on all that's involved with swapping complete axle assemblies to get 5-lugs on a 6-lug axle.
